Oil change interv running pto gen
   / Oil change interv running pto gen #11
I think anything you do would be just fine, but for me, if the oil looked dark at all, I'd change it and view the generator duty as a neat way to clean the engine internals via oil change.
   / Oil change interv running pto gen #12
Its a diesel, so it will be dark as soon as you start the engine...
Aaron Z
   / Oil change interv running pto gen #13
Is the valvoline a big improvement over the rotella?
couldn't tell you.
on regular changes in temperate.. probably neither better than dino oil :)
though I giuess the syn's are better film strength at startup, and have some better heat qualities.
in cold weather.. might be nice for the cold pour point winter wight.. etc.
   / Oil change interv running pto gen #14
Aaron Z
yep, unless new, rebuilt, or heavily flushed / changed in rapid sucession.. it goes dark pretty fast..
New Holland 650 Hay Baler (A53317)
New Holland 650...
2012 KOMATSU PC360LC-10 EXCAVATOR (A60429)
2012 KOMATSU...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2004 FORD F-350 XL DUALLY CREW CAB FLATBED TRUCK (A59823)
2004 FORD F-350 XL...
2024 PRO FABRICATION RTM-5.2K-Y REEL TRAILER (A59905)
2024 PRO...
2015 New Holland T4.95 MFWD Cab Tractor (A55314)
2015 New Holland...
