Oil Change 4035
/ Oil Change 4035 #1
tjus77
Montgomery, TX
Mahindra 4035
Anyone know what size socket it takes to take the drain plugs out of a 4035. And is it necessary to remove the PTO cover to get a wrench or socket to take the plugs out?
Thanks
TJ
/ Oil Change 4035 #2
I assume you mean hydraulic fluid and not engine oil? Which 4035; HST, Shuttle, or PowerShuttle?
/ Oil Change 4035
/ Oil Change 4035 #5
I asked the same question. I can't remember for sure but i think it was a 21mm. But it ended up not mattering. I could not get it to clear the sides of the nuts. A simple old crescent wrench is the tool of choice.
/ Oil Change 4035
did you have to take the shield off? I couldn't get a crescent wrench in there either.
/ Oil Change 4035 #7
No. I was able to get just enough of a bite with the crescent to make it work. The design/location of those nuts is ridiculous.
/ Oil Change 4035 #8
I too used a crescent wrench with success.
2012 Ford F-350 4x4 Ext. Cab Pickup Truck (A61568)
2012 Ford F-350...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
2025 HOMESTEADER 612IT 12FT ENCLOSED TRAILER (A59914)
2025 HOMESTEADER...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
2025 GIDDY UP 7'X14' BLACKOUT XTREME CARGO TRAILER (A62130)
2025 GIDDY UP...
