"Oil" cap on front gear case???
   / "Oil" cap on front gear case??? #1
sikmusicfreak8
Anza, CA
2005 Branson 4720, 8620 Backhoe
Morning folks.
Just serviced the tractor and in doing so remembered the box on the front of the gear case with the plug marked "Oil"; what is this for? When I open it, I don't see oil, there is no dipstick, I just see the gears. Nothing in the manual says anything about it. I always assumed it was my power steering pump, but I guess not.
Thanks
   / "Oil" cap on front gear case??? #2
Pic?..........
   / "Oil" cap on front gear case??? #5
where do you add your oil?
looks like a fill plug
Oil gets added at the valve cover.
   / "Oil" cap on front gear case??? #7
You can add oil there as well. It's an oil fill cap. Either one works.
Ok, good to know. What's the point of having two points I wonder?
   / "Oil" cap on front gear case??? #9
I see it on a lot of manufactures, not just branson. I suppose if that engine was put in a different application and the valve cover would be an easier spot to fill than the side.
   / "Oil" cap on front gear case??? #10
It is not easy to add oil on top since the hood opening is not great along with the exhaust sitting on top of the valve cover.
2000 Chevy 3500 Wrecker Truck (A52384)
2000 Chevy 3500...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
2018 Dodge Charger Sedan (A51694)
2018 Dodge Charger...
EZ-GO MPT 1000 Electric Utility Cart (A51691)
EZ-GO MPT 1000...
