"Oil" cap on front gear case???
   / "Oil" cap on front gear case??? #1
sikmusicfreak8
Anza, CA
2005 Branson 4720, 8620 Backhoe
Morning folks.
Just serviced the tractor and in doing so remembered the box on the front of the gear case with the plug marked "Oil"; what is this for? When I open it, I don't see oil, there is no dipstick, I just see the gears. Nothing in the manual says anything about it. I always assumed it was my power steering pump, but I guess not.
Thanks
   / "Oil" cap on front gear case??? #2
Pic?..........
   / "Oil" cap on front gear case??? #5
where do you add your oil?
looks like a fill plug
Oil gets added at the valve cover.
   / "Oil" cap on front gear case??? #7
You can add oil there as well. It's an oil fill cap. Either one works.
Ok, good to know. What's the point of having two points I wonder?
   / "Oil" cap on front gear case??? #9
I see it on a lot of manufactures, not just branson. I suppose if that engine was put in a different application and the valve cover would be an easier spot to fill than the side.
   / "Oil" cap on front gear case??? #10
It is not easy to add oil on top since the hood opening is not great along with the exhaust sitting on top of the valve cover.
UNUSED Metal Garden Arbor Trellis (A53117)
UNUSED Metal...
2007 Trail-Eze TE80HT48DD 48ft 48 Ton T/A Hydraulic Dovetail Trailer (A51692)
2007 Trail-Eze...
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A53426)
2007 PETERBILT 379...
Trojan 8T-50 46in Hydraulic Thumb Excavator Attachment (A51691)
Trojan 8T-50 46in...
2019 Nissan Sentra (A51694)
2019 Nissan Sentra...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
