Oh no! My bucket is broken!
   / Oh no! My bucket is broken! #42
Broken Track,
Thanks for confirming what a weldor told me about mirror welding on a ship. He told me about it in the early 70's and I've occasionally wondered if he was making it up.
Oh no, it is definitely a real thing on a ship. It has to do with the steel being reinforced with T-Bars, which are naturally T-shaped. When you get into corners and decks, its natural that those T-shapes make it impossible to see into those goofy corners, so a mirror must be used to see instead.
Incidentally the 100% welded rule for naval ships has nothing to do with strength. It has to do with longevity. If a seam is 100% welded, it cannot have rust start to form where the two pieces of steel meet, and otherwise would not be sealed with a weld. They figure a fully welded ship lasts about 20 years longer then a stitch welded ship because paint and sealants help keep out corrosion.
Obviously there are critical welds on a ship, and those are x-rayed, or use other non-destruction testing.
Interestingly, there are sections of a ship that are welded in a way that they will fail. That way if there is an explosion, the force blows the ships OUT and causes less damage. Its not a bad weld that does this, just undersized steel...like a crumple zone in a car.
But I never forgot that 300 sailors lives depended on my welds, or that the ship could see battle, or 50 foot seas.
   / Oh no! My bucket is broken! #43
Broken Track,
Thanks for that information. Back when the guy told me that, I was a welding school dropout and he had left welding and gone into retail. I sometimes wonder if he went back into welding.
Stuck
   / Oh no! My bucket is broken! #44
Good job!;)
It probably doesn't matter, but I always try to leave the craters in the middle of a weld, or in this case as far away from the start of the ripping action.
That is exactly what I was thinking when I saw the weld. I either weld from each side to the center, start the weld from the side with the most strain or in the case of a multi-pass weld, stagger my starts by welding in one direction, then next pass start welding from the opposite side. This tends to keep the welds even and reduces the possibility of a crack starting at the stopping point of the weld passes.
2020 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
2013 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2013 Ford F-250...
2015 Kenworth T400 T/A Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A52128)
NEW 2025 Load...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
