Offset flail mower recommendations
   / Offset flail mower recommendations #1
Mimijacq
Kioti NX5010
My tractor is 42 HP at the PTO with one set of rear remotes. I have established trails and will need to do yearly cutting to keep the brush from encroaching on the trails and fence lines. Any recommendations for a flail mower that has the most offset to the right possible via hydraulics? I’m looking for something with a cutting width of around 70”.
   / Offset flail mower recommendations #2
I have a 78" ditch bank flail it is the maximum for my Branson 8050 that tips the scales at over 11,000 pounds, that mower can give a person some pretty good pucker moments.
I wouldn't even recommend anything more then a 56" for a 4000 pound tractor and that may still be to much for your size tractor.
EMID-56 Embankment Flail Mower Intermediate Duty - Victory Tractor Implements
   / Offset flail mower recommendations #3
Lou - as I look at the pic you posted - the full 78 inches of the flail is offset - correct??
Just looking at that pic makes me pucker.
   / Offset flail mower recommendations #4
An orchard and vineyard shredder mower will provide you with the most side shift but as your mule has only one remote and not very heavy to counteract the over center forces created by the mowers movement it would not work.
The most off set is going to depend on the flail mowers actual total width and how much horsepower it requires.
Del Morino offers the Funny Top 158 model with mechanically adjustable side shift with pins and has a 62 inch cutting width.
The full side shift adjustment pushes the mower fully right with a measurement of 47 inches past the centerline of the tractor with 15 inches of cutting width to the left of the centerline of the tractor when it is adjusted 47 inches to the right. This mower will work for your needs.
The Maschio FURBA 180 is mechanically offset adjustment like the Del Morino funny top 158
and would work with your mule as well.
   / Offset flail mower recommendations #6
Yes, it can be, it will swing in behind the tractor and then out just a bit past the outside of the tires.
I can actually mow the full width of the mower outside the tires track. That has most of the mowers 1900 pounds off to the side of the tractor which will make her sway and bounce at times. when the mower is on flat fields and the rear roller is touching and supporting the mower it's not bad at all, but when holding the entire mower in the air when swung out over a bank it is a bit touchy.
To the original poster, the mower you listed the Nova BCRM 175 is lighter then my unit but your tractor is less then half the weight of mine with the mower at almost a 1000 pounds that is a lot of weight hanging off the side when it is in the air. I would say that the 155 with it's cutting width of 61"would be a better fit then the 68" of the 175 model but you don't have to extend the mower all the way out when working it.
   / Offset flail mower recommendations #7
Thanks for the followup explanation Lou. That is really a lot of weight hanging out there. I don't have a mower. Thinking of getting one. Maybe the Rhino TW25 or TW35. NEVER something like you have.
My valley on my driveway has steep side banks. They go down twenty feet to the floor of the valley. My Rhino 950 rear blade will offset. It's specifically so I don't have to drive on the edge when plowing snow. One slip and it would be a whole lot more than just a wild ride.
   / Offset flail mower recommendations #8
I have this one on a 4000lb machine. Like Lou mentioned it rocks the tractor pretty good if extended in the air but is very manageable if one is aware.
   / Offset flail mower recommendations #9
The standard duty is likely a better choice for the lighter tractors with yours being 800 pounds compared to over 1900 for the heavy duty one like mine.
I also like that they have the over running clutch built into the machine to save the pto brake.
   / Offset flail mower recommendations #10
I don't know what my Kubota M6040 has. If I push the PTO engagement lever to the OFF position while going at 540 pto rpms - it takes the chipper a LONG time to spool down.
What I do when finished with the chipper. Lower the tractor speed to idle and then disengage the PTO. The chipper, obviously, spools down much quicker.
Kubota HB84 Hopper Broom (A53317)
Kubota HB84 Hopper...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
159113 (A60429)
159113 (A60429)
2020 DRAGON ESP...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A56438)
2021 Unverferth...
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
