MatthewPaul
Last Friday I picked up an oddball 135 that is a basket case. The motor internals came in boxes, and the tractor was half stripped down. I think its a 135, the tins are anyway. It has a 3cy perkins, with a generator. The rear end appears to be a square housing like my buddies 175, it also has what appears too be a class 2 3pt. It has a 4speed hi/low transmission. The front axle is a solid non adjustable track width, with twin hydraulic cylinders. There is a diff lock on the rear, and it has disc brakes. It has solid 1 piece wheels, and not an inner/outer setup. There are 14.9/24 tires out back and 6.00-16 up front. There is yellow paint under the grey on many parts of the tractor, including but not limited to the hitch and front axle.
According to the tag on the dash, it is a 1972 135. It is a 9a serial number followed by six numbers.
it came with new in box perkins pistons, main and rod bearings, wrist pins, wrist pin bushings, etc.
The head was really messed up. It had been filled with water and left for some time. The valves and ports were badly rusted but everything cleaned up nicely.
Here are some photos of how I got it:
Over the weekend I split the tractor, and rebuilt the rotating assembly and head. Im just waiting on gaskets to get here. I'll post up some photos of that in a little while.
