Odd hydraulic action today...
/ Odd hydraulic action today... #1
mkane09
East TN
'10 Kubota MX4700HST, R4s
I've got a new MX4700 with a Long grapple. I recently had to replace a pinched hose on the grapple. I used it today for the first time since replacing the hose. At first, everything worked normally, but after about 10 minutes (and shutting the tractor off) the FEL would barely lift, the grapple was very slow opening and closing with no pinch force, but the curl function was normal. I thought the hydraulic fluid was probably low, but the sight gauge on the rear end showed at least half way up the window. I cycled all of the FEL and grapple functions MANY times, but it changed nothing. Added about 1/2 gallon of hydraulic fluid which did not change the level in the sight glass. Finally, about an hour later of run time, the FEL functions and grapple came back to life. So, what happened? Did it just take that long to purge the new line? Why did this affect the lift on the FEL? BTW, the HST worked normally throughout the entire day.
mkane09
/ Odd hydraulic action today... #2
Disconnect and reconnect all of your quick connects sometimes the move enough to pinch off flow. Been there done that.
1992 Polar 307 SS T/A Insulated Chemical Tanker Trailer (A64194)
1992 Polar 307 SS...
2021 John Deere 4044M (A64126)
2021 John Deere...
2022 EZ-GO ELITE...
2011 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2011 Caterpillar...
2013 International DuraStar 4300 General Cable T40-C 35ft. Bucket Truck (A64194)
2013 International...
Hoelscher 110 Bale Grapple (A64126)
Hoelscher 110 Bale...
