Oak boards thickness
   / Oak boards thickness #1
rosso1000
Italy
Lamborghini
I am planning to cut down several oaks this winter. I will keep some wood for my projects and sell the rest. How thick do I cut my lumber?
   / Oak boards thickness #2
Cut it 1". I prefer not planing until I'm ready. If you do plane it to 7/8.
   / Oak boards thickness #3
C'mon -
Give us hints as to what your projects are.
I like 3 to 4 inches for tabletops, 2 inches for trailer decking.
   / Oak boards thickness #4
How big is the log? Will it be quarter, rift or flat sawn?
Yeah, I am thinking about 25 mm.
I will be redoing our living room, and sell the rest.
Logs are 50 - 60 cm (20 -23 in) in diameter. Quarter, rift or flat sawn? That's another great question. What would you do?
   / Oak boards thickness #6
With no idea of quanity required I'd go with flat saw at one inch for the living room with one log. With the other log I'd go for a mix of cuts with some three inch quarter sawn and the rest cut flat or rift sawn to make for the best use of the log.
   / Oak boards thickness #7
I had a few logs cut 4 years ago and had it all cut 1".
1" might be easier to sell later and more projects to use it on unless you had something specific a thicker piece would be used for.
   / Oak boards thickness #8
As a sawyer, I can assure you that more wood has been wasted from being cut too thin in the first place, than cut too thick!
There's a reason the "standard" lumber thickness off the mill is 5/4. (I-1/4")
I mill my lumber 5/4 and AFTER it's dry and ready to use, I plane it to fit the job it's headed too.
SR
   / Oak boards thickness #9
As a sawyer, I can assure you that more wood has been wasted from being cut too this in the first place, than cut too thick!
SR
Agreed... 5/4 rough sawn unless you have specific projects in mind that require thicker.
   / Oak boards thickness #10
Most hardwood lumber is sawed on the 'quarter' system...4/4, 5/4, 6/4, etc. Each scale has an 1/8" built into it because old circle mills were notoriously inaccurate, and the end user, such as flooring mills for example, wanted to end up with a solid 3/4" thickness for their flooring after planing.
That means if you saw 4/4 lumber, you "should" end up with a green board 1 1/8" thick. You'll lose maybe a 1/32-1/16 of thickness in drying, leaving plenty to plane to give a 3/4" finish.
Unless you know in advance you have a project requiring 5/4 or thicker lumber, cutting the extra thickness to later pile it up in planer chips is a waste of wood, in my opinion.
I saw on a bandmill, for myself mostly, and I grade as I saw the log. The better grade stuff, I saw on the quarter system. The heart wood, and lower grade logs, I saw on the inch scale, which after saw kerf and drying, leaves me about a 7/8" board. Since I'm going to use the lower grade stuff for sheathing or pallets, or boxes and not plane it, that works fine
2012 CATERPILLAR 316EL EXCAVATOR (A51246)
2012 CATERPILLAR...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
UNUSED FUTURE HYD 16" AUGER (A51248)
UNUSED FUTURE HYD...
ECHO GT-225 GAS WEED EATER (A51248)
ECHO GT-225 GAS...
12 in Small Excavator Bucket (A52377)
12 in Small...
UNUSED FUTURE 24" HYD TILTING BUCKET (A51248)
UNUSED FUTURE 24"...
