O ring Madness
   / O ring Madness #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
Well, I think Terry let me down. Wondering if you guys have a solution before I wait a week for my package to arrive.
My tram pump... It has all sorts of hex bolts that act as plugs. Those plugs are leaking. I was thinking of just taking out all the o rings and putting in new ones but now I am not sure of a source, or what size for that matter.
Any thoughts?
   / O ring Madness #2
HF has a large assortment of O rings but I would go with a better quality like we have ACE HARDWARE stores around here or an auto part place, bring bolts with you for proper fit
   / O ring Madness #3
Any thoughts?
Glad to see you are getting a handle on all your leaks and hope your next post will be no more leaks. Auto parts place to get the orings. Wonder how much a whole box assortment of orings would cost. Sounds like soon you will get the upper hand on those leaks and will have a lot of experience to boot.
   / O ring Madness #5
I needed just one or two o-rings last week and got them at our local Ace Hardware store. When I was repairing mechanics' air tools, I kept lots of o-rings on hand; everything from very tiny ones to about 3" diameter. I often wished they didn't make so many sizes. For some jobs, an o-ring of approximately a certain size will work, while other jobs require o-rings of exactly a certain size and the sizes may be so close that you can't tell the difference visually.
   / O ring Madness #6
I have two kits of O-Rings that seem to cover ever size. I've had them for four years and use them all the time. I think each kit was about $20 each at my Hydraulic Hose store. They sold a bigger kit that had all the O Rings in it for $30 or $35, which I should have bought. I made the mistake of buying one kit, then a few months later realizing that I needed more choices in sizes.
For what it takes to take apart a fitting, I wouldn't take the chance on cheap O Rings. Do it once with quality parts and not have to do it again.
Eddie
   / O ring Madness #7
If you send me the o-rings, I will mail you back the proper ones. I have over 2,000 different o-rings in stock. O-rings are much more complicated than people think. Are they 70 durometer or 90 durometer? Are they nitrile or EPDM? Don't be fooled, there are different o-rings for fittings than you get in a generic kit.
By the way Eddie, I agree, move #10 up the list.
   / O ring Madness #8
OK , now that you told us that there are different types of o-rings, and size, how does the average person tell the difference, and what is a durometer?
   / O ring Madness #9
Yep o-rings can be fun. I have a small assortment of good ones 80 bucks. Durometer to o-rings is like rockwell to steel
   / O ring Madness #10
Durometer is the hardness of the o-ring material. The higher the number, the harder it is. You can either buy a durometer gauge, or, with experience, stick your thumbnail in it and see how far it goes.
Most hydraulic o-rings are nitrile. There are also fluorocarbon o-rings for other hyd applications. Some of this depends if the o-ring is static or in a reciprocating application. I won't even get into quad rings.
I don't mean to scare anybody off here. If you are talking about simple plugs, then your average auto store 70 durometer kit should be okay. I wasn't trying to make a sale here as I do not charge for o-rings. If you mailed them to me in a self addressed stamped envelope, I would send you new ones for free. It's not worth wasting the invoice. You just have to be careful as on your average tractor, there are at least 5 different types of o-rings that I can think of off the top of my head. Flange seals are 90 durometer. I have seen guys install the 70 durometer rings in and complain because the fitting leaks. That's one reason why I give new o-rings with any fitting requiring an o-ring when I make a hose.
As far as size goes, there is a dash number that corresponds to the diameter of the o-ring cord, then to the inside diameter of the o-ring. There is a chart in the o-ring section of the seal catalog on this website- Hercules Sealing Products. Good technical info here too.
2021 KUBOTA SVL75-2 SKID STEER (A51246)
2021 KUBOTA...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A52384)
2011 Autocar ACX64...
Duetz Power Unit (A50120)
Duetz Power Unit...
JOHN DEERE Q820M LOT IDENTIFIER 81 (A53084)
JOHN DEERE Q820M...
Skid Steer (A52377)
Skid Steer (A52377)
2009 International Frazer Bilt X-514 Ambulance (A52377)
2009 International...
