O ring Madness
/ O ring Madness #21
Thanks, Andy, for the information and Woodland Farms for starting the thread. I've used orings for decades and only today I'm learning that they come in different hardness ratings.
I'm reminded of the time back in the late sixties aboard a submarine. It was customary to send new and naive shipmates after the impossible (left-handed crescent wrench for example). Someone sent the new guy after an "o-ring splicing kit".
A few hours later he returned to the watch station with one.
We'd never known that there's a big oring that goes around the main driveshaft in nuclear subs, and it has to be spliced together when installed. The joke was on us.
Now I realize we should have sent those kids after a durometer gauge!
Phil
/ O ring Madness #23
MrJimi said:
I read Phils reply and I thought about it and I did a search !!
Get your O ring splicing kits here !!
Great one Phil
I have that exact kit. It does both metric and standard o-rings. I used it once for a customer, got him out of a big jam. Making nlarge o-rings is pretty easy, it's when you get into the smaller ones that can be a real pain.
/ O ring Madness #24
Wayne County Hose said:
Fitting o-rings are generally 70 durometer, the hardness in your general kit. Flange o-rings are harder, 90 durometer. I didn't mean to put a scare into anybody about their o-rings. Go ahead and keep using your kits like you always have. Just be aware that if you have installed a new o-ring and you still have a leak, that maybe you need a slightly different o-ring.
Flat face fittings that use an 0-ring are a different size than you find in most generic kits. They tend to be smaller diameter. Using one too thick will probably result in a leak. I hope this clears things up. Don't worry about what you have always done that works. Worry about it if it doesn't work.
Durometer
Did anyone know this word has been around since 1920. I had never heard or used this word before the other day. Anyway, below is a definition of Durometer. I don't think most of us need be concerned with the hardness of the three things listed below. I am concerned when you take an o-ring off, and it is flat ,hard or brittle. I know it is supposed to deform to seal, and dependent on the fluid used and the heat, I would recommend that if you take something apart with o-rings, to go ahead and replace with new o-rings while it is apart.
Durometer is one of several ways to indicate the hardness of a material, defined as the material's resistance to permanent indentation. It is named for instrument maker Albert F. Shore, who developed a measurement device called a durometer in the B9200. The term durometer is often used to refer to the measurement, as well as the instrument itself. Durometer is typically used as a measure of hardness in polymers, elastomers and rubbers.[1]
/ O ring Madness #25
The size and type of material is listed in McMaster Carr search for Orings
(unfortunally the URL for each page dosen't come up)
McMaster-Carr
they have the gauges and sizes dimensions.
here is a pdf of the dimensions
they have a lot of information on there pages
tom
  • oringsize.pdf
/ O ring Madness
So, I talked to Terry today about getting O-rings for the Tram pump. He said just go to the hardware store and get them. I said what kind. He said size 10 or 12. I said what kind. There was silence on the phone and then he said "O rings". A little knowledge is very, very dangerous
Terry is a great man. Impressive and very kind Do not take any of this as an attack on him. He has done me numerous favors and has always been there to answer my questions.
So, Wednesday I will go to Napa and get me some o=rings. Then I will send my old ones to Wayne County with a SASE...
Carl
/ O ring Madness #27
Carl
I think you got the correct advise from Terry. If you called the pump manufacturer, you would probably get the same advise. This ain't the space shuttle.
/ O ring Madness #28
Carl
Carl,
Did you ask the parts guy for the o-ring set for your tram pump. That seems like an odd response from Terry. That sounds like someone evading.
I ask the parts guy about the O-rings, and he asked me which tram pump I had. I didn't know which model, so he emailed a parts breakdown for both pumps.
/ O ring Madness
I thought Terry was the parts guy... Terry had forgotten to put the set in my package and said it was just O-Rings... I will go to Napa today, give it a try but keep my originals... It is frikin cold here today, nearly 35... brrr..
/ O ring Madness #30
Carl,
Terry is the Service manager. Kieth is the parts guy.
/ O ring Madness
Well, it all went south today.
The leak is coming from a small hose coming out of the drivers side of the tram pump. It is coming out at the brass fitting that mates with the pump itself.
First problem is that all the hex plugs that plug the empty tram holes are in the way. Second, I removed the upper brass fitting that is used to evacuate the air from the pump and it has this proprietary gasket / washer.
I called Terry, he is sending everything I need out tomorrow.
Also, I took the advice of a friend and JB welded my cracked tank. Well, that let loose today. Grumble. And my dog died. That was actually the worst part of the day.. Using the tractor I love to bury the dog I loved...
Tomorrow is a new day.
Carl
/ O ring Madness
ksimolo said:
Carl,
But not cold enough for a repeat of the writing in the snow incident - thank god!
Ken
Nope snow is gone. Don't drink downstream from me, though...
/ O ring Madness #34
Carl,
My condolences on losing your dog. I lost mine in my house fire 2 months ago. I did find her and gave her a proper burial. I lost my absolute favorite almost 4 years ago. I still miss him.
/ O ring Madness
Man... House fire... That really, really sucks. We knew it was coming, but never easy...
But, we had been looking for a boxer mix puppy for a while (so these dogs could help train it) and finally found one a couple of weeks ago (rescue dog) so we get the new pup this weekend. My life continues its never ending sense of turmoil ;-)
Carl
/ O ring Madness #36
Been away for a few days and this AM this thread caught my eye. My concers were soothed as soon as I saw Wayne County make his initial post. Knows more than is needed for this kind of discussion.
For those really interested, I'd suggest to contact your local industrial supplier and see if they can supply you with application books the major mfgrs publish. Alt is contact Applerubber or Parker-Hannifin, both are big names in the o'ring/seal business and have publications available.
In addtion to size, the next most important thing to know when selecting o'rings/seals is, what is the envrionment this product will come in contact with. Includes materials i.e. anything the seal is going to be coming in contact with, temp, exposure to light, arcs, etc.
If the o'ring fits into a machined recess of some kind, then o'ring x-sect become important as amount of compression is important. Material selection also come into play as various compounds are subject to different amounts of compression set. The o'ring always needs to maintain some pressure against the sealing surface. Wrong material which is not suitable for the environment may deteriorate and fail prematuraly.
Hope you get the picture I'm trying to put forth. try and get an application book so you can select the correct material for the application and there will be less chance for something to go wrong.
Durometer is the industry std for measuring the hardness of elastomers. The measurement has been around for decades. Durometer testers come in a variety of price ranges from modest to high cost. Designs vary depending upon what you are trying to measure.
Good discussion guys.
/ O ring Madness #37
I do need to correct myself. All fitting o-rings are 90 durometer. The generic kits are 70 durometer. Now don't kill yourself trying to find a 90 durometer kit, if you have an o-ring blown out on a fitting and all you have is a 70 durometer kit, it will probably work just fine. Just remember that if the softer o-ring blows out, you will need to get a harder one.
Another little fyi, the nitrile o-rings (buna-n) in your kit are not compatible with brake fluid. For that, you need a BUNA-S or natural rubber o-ring.
2015 Chevrolet Silverado 2500HD Service Truck (A61573)
2015 Chevrolet...
378908 (A61166)
378908 (A61166)
2019 TAKEUCHI TL12V2 SKID STEER (A64279)
2019 TAKEUCHI...
2016 WEILER P385A ASPHALT PAVER (A63276)
2016 WEILER P385A...
2022 Bautista Welding and Custom 40ft. 10 Ton T/A Gooseneck Flatbed Trailer (A61573)
2022 Bautista...
2019 Chevrolet Malibu Sedan (A61574)
2019 Chevrolet...
