nylon hose barb
/ nylon hose barb #1
Eric_Phillips
Platinum Member
Rochester, NY
FarmTrac 270DTC
I am trying to hook up a post driver to my tractor. The fill port on my tractor is not in a place that is easy to tie the return from the driver to. Would a nylon hose barb hold up to the hydraulic system? It shouldn't have to hold any real pressure.
/ nylon hose barb #2
It will probably be OK, but may get brittle in time and break. Home Cheapot-Lowes-and TSC should have brass ones that would be better in the long run I think.
/ nylon hose barb #3
I agree with Kenny.
A nylon barb should work but not only could it get brittle, it could get busted off easily too in case you bump it or whatever. You can get all kinds of barb fittings at Discount Hydraulics. I recommend using the steel ones shown here.
Hose Barbs
2016 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2016 GENERAC...
GENERAC MOBILE  MTL65 LIGHT PLANT (INOPERABLE) (A67714)
GENERAC MOBILE...
2013 STEPHENS CRUDE PUP TRAILER (A67714)
2013 STEPHENS...
2018 GENERAC MOBILE PRODUCTS MAGNUM LIGHT/WATER PLANT (A67714)
2018 GENERAC...
2014 Kobelco SK210LC Hydraulic Excavator (A66734)
2014 Kobelco...
2006 WINSTON AP22024AL-DC T/A 24FT TRAILER (A66091)
2006 WINSTON...
