NX6010 suction side hydro leak
   / NX6010 suction side hydro leak #11
Thanks for the update. Glad the dealer actually came out and listened to it.
Suspect you're on target with something within the hydro pump itself just not right. Maybe a machining tolerances, seals, combo thereof.
Anyway, its all in progress now.
So looking forward to the final solution.
Regards
   / NX6010 suction side hydro leak #12
Well, had the dealer out, showed him the problem and his exact words, "that's not right". So, hopefully there's something that is really wrong that they can fix. I've had a string of "hydro issues" that I suspect all come back to this. I had issues with my tractor "making oil" since new (pull the stick cold, it's in range, pull the stick hot, it comes out the hole it's so overful). Also, if I open the fill hole, I can actually see bubbles (tiny, bubbles) in there and hear something that sounds off. So; we'll see, but the dealer took the tractor tonight and said his best guess is something in the hydro pump that's not sealed.
Thanks for the video Eric, and yes, that's kind of what mine sounds like. Mine is worse, but it's the same basic noise. Here's the thing though, my JD (also a hydro) doesn't do this at all. I go out start it, and all the hydro is smooth as silk from 30 seconds in. So, if this is "normal" then it's not a feather in Kioti's cap, that's for sure. I'm petty sure it's not normal though, I should have recorded video for you guys, but, when I get it back, I'll get some video of it "fixed" for comparison.
Not knowing what all the other issues you have been having with your hydraulic system, and just reading this thread, I've been looking at the flow diagram of a dk45se, unsure of how similar it is to the NX other than size. High on my list of suspects would be a component of the Joystick valve or 3pt lift cylinder, both of which are fed from the 1st hydraulic pump. The 2nd hydraulic pump feeds the modulator valve, which services the pto clutch, 4wd shifting, steering, and HST functions.
I suppose its in the dealers hands now, but if the problem persists after return from the hospital, put your hand on both hydraulic pumps, see if one is unusually hotter than the other after having operated the problem. Put your hand on the joystick valve, feel for chatter/excessive heat there. Same for the modulator valve. If you can get close enough to the problem, its exact location may become apparent, and could be as simple as changing out a relief valve. Which would be.... you know.........a relief.
I'll see myself out.
Let us know what they come up with, I hope it works out alright for you.
   / NX6010 suction side hydro leak #13
Your oil level will rise as it warmed up to the point the oil comes out the dip stick and has some foaming. Normal.
Also industry normal accross a wide range of vehicles.
Tractor is back. Dealer asked me if I wanted it back or wanted him to hold onto it until he could speak with Kioti. They are pretty sure the issue is the pump, they replaced everything on the suction side and put a clear tube in where the rubber connector is between the hydro filter and the sump (suction side) so they can see the bubbles. Tractor is also out of spec for time to raise the loader, like way out of spec (almost double the time), so all indications are the pump at this point. Dealer is going to get with Kioti and get them to authorize the pump replacement but won't be able to do that for a week, so brought the tractor back to me so I had it. I've been really impressed with this dealer, they are new to me and I'm really liking dealing with them. Kind of upset that it's such a major part going out, but, to be honest, I'm near sure that this was a factory defect in the pump. It's never been "right", I just didn't realize it because I had no comparison point (I'd only used gear tractors before). When I got a little JD a few months ago (also a hydro) it was clear as day to me that "somethings not right" with the Kioti. The JD is smooth as silk, doesn't "make oil", doesn't whine, doesn't stutter. And that's exactly what the dealer said when he drove it around my property, he made it about 50 feet and stopped. "I know what your feeling, it's not right". So it's not Kioti vs JD, it's just my inexperience with hydro drive tractors.
Either way, I'll keep everyone updated as to the final resolution, but it'll be a few weeks before anything happens. At least I have the tractor back and can get some work done again! Seems the minute it's gone, about 100 things pop up that need doing. I asked him "am I gonna hurt anything running it like this" and he kind of laughed. Yeah, might hurt the pump, but we need to change the pump, so... Have at it. ;)
Man, I will have to get some video of this an upload it to you Youtube for you guys to look at. With the clear tube in the suction line you can see it clearly, first bubbles and then, when it "smooths out" it's just foam, looks like you put soap into the hydro line. White foamy soap. Crazy how much air is in there. Of course, because it's been cold, it's working awful, gotta let it warm up for 30 minutes before it'll feel like moving. Same situation as before, once warm (and the hydro fluid is all foam) it works pretty well.
Explains how I've been "making hydro oil" in this tractor since I got it though. I'm pretty sure this has been a day 1 problem that's just gotten worse. Dealer has to get Kioti to authorize a new pump which he'll order up for me, hopefully that's the end of the problem. Good news is, it's behaving so badly now, it's going to be night/day when this fixed. There's no "I think I got it". No, especially with the clear line in there on the suction line, it's easy to see there's a problem (and hopefully be equally easy to see when it's resolved).
   / NX6010 suction side hydro leak #16
Clear line awesome.....
side bar question.....is the clear line stout enough for full time use?
Sure sounds like an excellent 'mod' that would be a handy way of keeping an eye on the hyd. system.
IF the hose is stout enough that is...heh....
   / NX6010 suction side hydro leak #17
Many types of tubing you'll see around. Its hard to say what they used at the dealer, but the most common, readily available options are as follows:
* Tygon PVC is typically used for drainage viewing but only good for 50psi and 160F or so.
* UV resistant Clear PVC is good for 220F but only 50psi or so.
* PVC with polyester braiding is good to 350psi, but only up to 150F, and not perfect for viewing.
You can go a bit out of your way and find some much better, longer lasting options.
* FEP clear tubing for chemicals is good for 400F and around 300psi and is UV resistant, and has around a 2" bend radius for 1/2 tube, a bit hard but good stuff.
* Crack-Resistant Teflon PFA clear tubing for chemicals is good for 500F and around 400 psi, and has a similar bend radius as the above
* Extreme temp PTFE Teflon semi clear tubing is good for 500F and around 300psi
There are a lot of options if you take a look in McMaster Carr. Some of these options may be to hard for this application, and its difficult to say for sure until you can get your hands on some of it. I know pressure rating will not need to be very high, but you'll still want to stay clear from anything rated too low. Temperature rating is quite important, higher the rating, the longer it will last. Your oil should never see 180F or above, but the higher the rating the better.
My choice would be the FEP clear tubing for chemicals, along with all of its other great properties, its also highly UV resistant. Its the hardness that you would have to try out and see if it could make the bends and fit over fittings that you might need it too.
Ask the dealer specifically what hose they used, should let you know if you can leave it on.
Here's a video (poorly shot, but you can see the problem). ;)
I think the fitting that was put in is thread reinforced PVC. I show it in the video so please, PVC experts, can I keep that as the line or do I need to replace it with the stock rubber boot or something else? It's about 40 degrees here today, this problem is very cold dependent, the colder it is, the worse it is. So today it was pretty bad, in the summer, sometimes it would be near "perfect" and other times it would just need a minute or two to settle down. The dealer still is pretty sure it's the pump, just seems to strange that all that air is getting in on the suction side like that from a bad pump though.
Kioti Hydro Issue - YouTube
This video is bad, I just don't have time to work on it. You may have to jump about 2 mins in, the beginning 2 mins are all dark. I asked Youtube to trim it, but it may not be done for a bit, just jump ahead 2 mins if you have a black screen.
Thanks!
   / NX6010 suction side hydro leak #19
FEL lift sucks. Same with 3PH. Noise coincides with 3PH lift stutter. Get a new pump.:thumbsup:
   / NX6010 suction side hydro leak #20
Yeah, I'm leaning pump now too. Interesting, does your power steering studder at all too? as that comes from pump #2. your loader valve and 3pt hitch come from pump #1
5' ROTARY MOWER (A52706)
5' ROTARY MOWER...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Turfco Mete-R-Matic XL Towable Golf Course Drop-Style Topdresser (A55973)
Turfco...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
Informational Lot - Shipping (A56436)
Informational Lot...
2017 BOBCAT T770 SKID STEER (A52709)
2017 BOBCAT T770...
