NX6010 Potential Fuel Line failure
   / NX6010 Potential Fuel Line failure #1
cutthroat
MO
Kioti RX7340PC
So while doing some inspections today I noticed my fuel line from the tank was rubbing on the frame and had already removed quite a bit of rubber. I fabricated a metal shield out of air duct sheet metal and zipped tied it on. Think it should work. Poor design by Kioti.
   / NX6010 Potential Fuel Line failure #2
Nice "repair". Agree that is either bad design or someone put yours together improperly. Surprised the Eric or other high hour NX owners haven't noticed the same thing.
   / NX6010 Potential Fuel Line failure #4
heater hose works well for those situations. It looks like an assembly issue rather than a design issue. One thing to do on any new machine is to look carefully for those exact things. Minor. Looks like you caught it in time.
   / NX6010 Potential Fuel Line failure #5
If it is the line that runs across the top of the transmission, I already rerouted it when I was installing my third function at the seven hour mark back in July of 2014.
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2010 Ford F-150 Single Cab Pickup Truck (A55973)
2010 Ford F-150...
1999 Volvo WG T/A Dump Truck (A55973)
1999 Volvo WG T/A...
American G-Model Pump Jack (A56435)
American G-Model...
2014 Dodge Charger Sedan (A55973)
2014 Dodge Charger...
2020 Toro Pro Sweep Vacuum (A55787)
2020 Toro Pro...
