NX6010 loss of power
   / NX6010 loss of power
Yeah I did this already, a lot of fuel came out, not sure if there was water in it or not. My dealer was in the area tonight and picked it up. They should get back to me in a couple of days as to what they have found.
-Craig
So talked to my dealer today. ALL fuel injectors were bad. So now they are just waiting for them to come in.
-Craig
   / NX6010 loss of power #14
Looks like you got a whole batch instead of my one. At least they figured it out.
Got tractor back tonight. All fixed. Fuel Injectors were replaced and she is running good again. Also got my ECU reprogrammed and they replaced some cracked interior panels.
-Craig
   / NX6010 loss of power #16
Humm mine did the same thing yours the other day, I had been using the cutter for about 4 hrs, got to a spot that had a pretty good incline. Tractor really started losing power, after about 30 min of babying it, I noticed it slowly began to come back to having full power. Been fine since.
   / NX6010 loss of power #17
Folks, I think you need to check for H2O in the fuel and especially proper function of the fuel filter. Liquid water should not get through a functioning fuel filter but maybe it did in your case. The fact this happens on slopes and turns implies a sloshing issue. Actual water in the fuel can blow the tips odd the injectors when the water flashes to steam. You may have a defective fuel filter that passes water which blows the injectors.
There will always be a small amount of water in a fuel tank (from condensate) but not enough to plug a fuel filter.
   / NX6010 loss of power #18
I too wondered about the fuel slosh, I know mine isn't water , but wonder if it was something with the low pressure lift pump, maybe sucking air bubbles or something. I was close to empty, and after fueling back up and running for another 15 minutes or so it straightened back out as if it the air worked itself out. Had the same type of issues with our big tractors and combines over the years.
2013 Chrysler Town & Country (A56859)
2013 Chrysler Town...
UNUSED LANDHONOR LHR-EPC40 PLASMA CUTTER (A57193)
UNUSED LANDHONOR...
2021 Ram ProMaster City Van (A56858)
2021 Ram ProMaster...
Massey Fergusson 4710 (A53317)
Massey Fergusson...
2014 Kubota BX25D (A53317)
2014 Kubota BX25D...
Bi-Parting Driveway Gate (A55853)
Bi-Parting...
