NX5510H rear remote
   / NX5510H rear remote
thank you very much hillwood, I will get all the rear remote kits I can get.
Given the list of implements you intend to use, and assuming six foot implements, the only one that could make good use of more than 45hp is the snowblower. Even then if you are clearing less than a foot at a time I'd guess there would be little difference between the 45 and higher hp versions.
I run a DK40se which is essentially the same tractor as the NX with different engine. I use a BH, box blade, 5" chipper, bush hog and flail mower. Never needed more HP than available and I only rarely even run the engine at full PTO rpm.
thank you very much IslandTractor.
I just added a new thread listing the tasks I have in mind. for box blade, I want to use 84" to speed up the process. Please let me know if, after seeing my list of tasks you still think NX4510 is more than enough:
http://www.tractorbynet.com/forums/...ioti-nx-rx-horsepower-needed.html#post4808509
Thank you
   / NX5510H rear remote #13
You want the rear remote kits. Just like everyone is saying, you will need them, they are inexpensive and easy to install.
hi hillwood, since you have NX5010HST, can you please tell the maximum number of rear remotes that I can add (I am already getting a backhoe)? Also, can you add a 3rd function to your machine for FEL?
Is automatic PTO a good option to get?
Thank you
1998 INTERNATIONAL 9200 TANDEM AXLE DAY CAB (A57880)
1998 INTERNATIONAL...
2013 Buick Enclave SUV (A55853)
2013 Buick Enclave...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
2017 Polaris 500 Ranger Diesel Utility Cart (A55787)
2017 Polaris 500...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
John Deere 4x4 Tractor (A55973)
John Deere 4x4...
