While moving some logs around yesterday the range selector lever flopped around so now I could not get out of low range. Crawled under to see what caused the problem. The roll pin holding the lever to the shaft linkage snapped. Luckily I had a captive pin with a bale attached so used that after turning it down a bit to fit the hole. Tractor has about 500 hours. Easy fix. Maybe this can help others with similar problem. Bob
