MichiganIron
Silver Member, Advertiser
- Joined
- May 12, 2008
- Messages
- 845
- Location
- Central Michigan
- Tractor
- Full line of KIOTI Tractors, BEFCO and Worksaver Implements
Got home and started right in working on changing out the filter housing. You were right... The banjo fittings were tough to get off and back on. Everything else was a piece of cake. Wound up re-using the same oil (drained into a brand new clean 15 gallon container), and used (stole?) my wife's Whataburger cup as a dipper to transfer the oil from the container back to the tractor.
Bottom line, changing out the filter housing does NOT appear to have worked. When I started it up, I cycled the loader a few times, moved backwards and forwards a little bit, and didn't feel any hesitation or hear any noise. Thought I was good! Decided I would go out and cut some grass, and when I throttled back from PTO speed after cutting for an hour, I heard my noise start up again. I left the engine running and opened the reservoir cap and found it full of bubbles.
I've tightened up every suction side bolt I could find. Short of some special DIY testing technique, the only thing I know to do is take it to the dealer and let them have it for a few weeks of troubleshooting. I'd really hate to do that...
Call me disappointed. :-(
Hoping you checked the air breather on the transmission. We have solved these issues several times just by cleaning out the air breather. If it is plugged or not breathing properly, it caused cavitation of the hydraulic fluid.....the result is jumpy hydraulics.
