NX4510 HST Cab A/C issue
   / NX4510 HST Cab A/C issue #41
Mine does blow dried air even at temps well below zero. The cab can be fogged up, and once A/C starts working, the windows clear up. Hope it isn't damaging anything.:confused::confused:
So does my tractor and the AC system will work with ambient temperatures below freezing but it will not work until that thermister is above freezing. If you happen to roll out of a heated garage, then the AC will work right away. If you happen to be like myself where the tractor sit outside all year, the AC will start working if I'm lucky after about 20 minutes into plowing snow.
   / NX4510 HST Cab A/C issue #42
you should not run an air conditioner at 58 degrees F or lower!.. unless you KNOW it's specifically designed for that!.
   / NX4510 HST Cab A/C issue #43
The HVAC system in the Kioti NX series is, in fact, specifically designed to use the AC to dehumidify the cabin air during heater use in winter conditions. The "Thermicon" system uses a thermistor in the cab roof with a set point of 32F to protect the compressor, etc. The question here is what's going with Kioti Dave's tractor in particular that's keeping it from operating as designed.
   / NX4510 HST Cab A/C issue #44
yes, there are exceptions. if the AC in Kioti Dave's tractor operates normally in warm weather, then he may have a bad thermistor. if it does not operate normally in warm weather, then he may have a mis-wiring issue.. the dealer should be fixing this, they have the gauges and other tools to fix this.. another thing, the pressure goes down in cold weather, if he has a low charge, the low pressure switch will prevent the compressor from going on!.. also, the thermostatic expansion valve has a temperature sensor, if that is sensing the evaporator coil is freezing, it will make the compressor cycle too..
   / NX4510 HST Cab A/C issue #45
Reading back through my quoted post, I should have said that it's Kioti617's HVAC that seems not to be operating as designed. Kioti Dave's seems to be operating normally in cold weather after his dealer worked on it in November 2019. I should also have been more precise, for future readers of the thread, in describing the Thermicon system by distinguishing more clearly between ambient air temperature outside the cab roof, and ambient temperature within the cab roof space where the thermistor is located. (See graphic in my post #29).
As I understand it, the thermistor, with a nominal set point of 32F, is reading only the condition of the system within the cab roof space. So as long as conditions there are above the set point, the outside temp could be way colder, as Kioti Dave's and Eric's experience has shown.
At least that's my understanding of how the Thermicon design works. Since my NX is garaged in tempered space, the thermistor is always registering above the set point when started up. Plus, the temps here in No. VA have not really been cold enough this winter to test the limits of operation even when outside! With the forecast next week for temps reaching 60F, that's not likely to change. I'm not complaining about it, but it would have been nice to have used my rear snow blade with hydraulic offset at least once this season. It's still wrapped in its tarp on sleepers behind the barn. :laughing:
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A57024)
2023 Unverferth...
1339 (A57192)
1339 (A57192)
16FT box truck (A53424)
16FT box truck...
2014 Nissan Rogue Select SUV (A55853)
2014 Nissan Rogue...
1355 (A57192)
1355 (A57192)
2020 Terex RL4 Towable Light Tower (A55851)
2020 Terex RL4...
