NX4510 CEL (check engine light) on and can't turn off
   / NX4510 CEL (check engine light) on and can't turn off #1
Kioti Dave
Leduc Alberta Canada
2016 Kioti NX4510 HSTC
Had a coolant hose come loose which set ofF the CEL. Reattached hose, filled coolant and now still have the CEL. Anyone know how to turn it off without the dealer?
   / NX4510 CEL (check engine light) on and can't turn off #2
Maybe try disconnecting the battery for a min.
   / NX4510 CEL (check engine light) on and can't turn off #4
Maybe there’s a reason for the light….like an airlock? Check for any other issues, even though you’ve addressed the loose hose 😉
Thought of that. But it's been 25 hours since, and everything seems to be working normally. Guess I'll just need to have dealer send out a service guy.
Keep us updated 😉
Will do. Having a hard time paying the dealer to send someone out to just clear the CEL. Probably a couple hours with the travel time. Just hit 1000 hours and despite a few early problems, the last 600 hours have been without any issues. (had an early main seal leak, bad injector and turbo. All replaced on warranty.)
2019 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A60460)
2019 Ford F-550...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 LOAD TRAIL 35+5 GOOSENECK TRAILER (A58214)
2019 LOAD TRAIL...
1997 Ford Tandem Dump Truck (A59814)
1997 Ford Tandem...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59575)
2021 KENWORTH T680...
