Nothings working
/ Nothings working #1
ditch diggin
ditch witch trencher (old)
I have a 1973 Ditch Witch trencher while digging lost all hydraulics.. I pulled the pump off front all teeth seem to be intact working properly. Any help of what to look at next would really be great.... Thanx in advance.. If pump is bad is there any way to check it cause it is very pricey to replace...
/ Nothings working #2
Might even be an electric problem....get some documentation like electric and hydraulic drawings....scan and post....
/ Nothings working #3
/ Nothings working #4
I have the Case 360 trencher, and the pumps are belt driven. Can you determine if the pump shaft is turning? Put a gage in the system and see if you have any pressure anywhere. Check fluid level.
2002 Kenworth T300 TMA Attenuator Truck (A64194)
2002 Kenworth T300...
More info coming soon (A61574)
More info coming...
2007 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A64556)
2007 Dodge Ram...
HORST RSW HEADER CART (A64278)
HORST RSW HEADER...
UNVERFERTH GW530 GRAVITY WAGON (A64278)
UNVERFERTH GW530...
2018 CATERPILLAR 320 EXCAVATOR (A65053)
2018 CATERPILLAR...
