Nothings working
   / Nothings working #1
ditch diggin
ditch witch trencher (old)
I have a 1973 Ditch Witch trencher while digging lost all hydraulics.. I pulled the pump off front all teeth seem to be intact working properly. Any help of what to look at next would really be great.... Thanx in advance.. If pump is bad is there any way to check it cause it is very pricey to replace...
   / Nothings working #2
Might even be an electric problem....get some documentation like electric and hydraulic drawings....scan and post....
   / Nothings working #3
   / Nothings working #4
I have the Case 360 trencher, and the pumps are belt driven. Can you determine if the pump shaft is turning? Put a gage in the system and see if you have any pressure anywhere. Check fluid level.
2013 Freightliner Hydro Vac Truck (A53117)
2013 Freightliner...
2015 Hustler Super Z VX4 72in Zero Turn Mower (A51691)
2015 Hustler Super...
Yale MPB040-EN24T2748 4,000lbs Electric Walk-Behind Pallet Jack (A51691)
Yale...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
