not turning over
/ not turning over #1
reilhunting
anywhere, vt
kioti dk45
have a 20yo +/- kioti dk45. having problem starting and draining of battery. already replaced key switch. there are two relays/switches that buzz when key is turned off/on. the timer relay and one in the engine compartment mounted in front on of the fuel tank next to the preheater controller
/ not turning over #2
Hi. Welcome.
I would start with checking/tightening the ground wires and any other loos connections you find.
The battery drain indicates either a short or a loose wire that is causing a drain.
/ not turning over #3
I would take all the battery cables off and clean them and their mating surfaces up and coat them with dielectric grease before putting them back together, first. Then see if it will start.
If it won't start then, with the key switch in the off position and the tractor in neutral and the brakes locked on, I would take a jumper wire and jump from the positive terminal on the starter solenoid to the single small wire terminal to see if the engine will turn over.
2019 Dodge Charger AWD Sedan (A64557)
2019 Dodge Charger...
2016 Ford F-250 Auto Crane 3203 3,200lb. Crane Service Truck (A64556)
2016 Ford F-250...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
1980 19ft Sailboat w/ 2018 Continental Trailer S/A Boat Trailer (A64557)
1980 19ft Sailboat...
NEW HOLLAND C232 SKID STEER (A65053)
NEW HOLLAND C232...
2015 Mercedes-Benz C300 Sedan (A64557)
2015 Mercedes-Benz...
