not turning over
/ not turning over #1
reilhunting
anywhere, vt
kioti dk45
have a 20yo +/- kioti dk45. having problem starting and draining of battery. already replaced key switch. there are two relays/switches that buzz when key is turned off/on. the timer relay and one in the engine compartment mounted in front on of the fuel tank next to the preheater controller
/ not turning over #2
Hi. Welcome.
I would start with checking/tightening the ground wires and any other loos connections you find.
The battery drain indicates either a short or a loose wire that is causing a drain.
/ not turning over #3
I would take all the battery cables off and clean them and their mating surfaces up and coat them with dielectric grease before putting them back together, first. Then see if it will start.
If it won't start then, with the key switch in the off position and the tractor in neutral and the brakes locked on, I would take a jumper wire and jump from the positive terminal on the starter solenoid to the single small wire terminal to see if the engine will turn over.
2008 Honda Civic Coupe (A64557)
2008 Honda Civic...
2020 CATERPILLAR D5K2 LGP CRAWLER DOZER (A65053)
2020 CATERPILLAR...
2020 JOHN DEERE 333G SKID STEER (A65053)
2020 JOHN DEERE...
2022 SANY SY35U EXCAVATOR (A63276)
2022 SANY SY35U...
2007 MACK CTP713 DUMP TRUCK (A65054)
2007 MACK CTP713...
2012 Ford F-250 Crew Cab Pickup Truck (A64556)
2012 Ford F-250...
