not sure what trailer to get. need some help
   / not sure what trailer to get. need some help #1
Rackluster
I just bought a jd 3032. I'm going to be pulling that tractor and loader plus a box blade about 60 miles. Going to make the trip pretty regularly with my f150( currently no brake controller).
Wondering what you all think might be the best trailer type and size.
By the way I think the tractor and loader is about 2500 pounds. Just a guess.
Thanks all!
   / not sure what trailer to get. need some help #2
Rack,
Get an accurate weight and then post the numbers. Do you have loaded tires? There are many variables, but you will need tandem axles and brakes, I would think.
   / not sure what trailer to get. need some help #3
Without loader:
Weight: 2,175 lbs [986 kg]
A good quality 7000lb x 16-18' equipment trailer (not a car hauler) should do the trick. it will have ramps with feet to take the weight of the tractor while you drive on. A 7000lb trailer can haul about 5500lbs. Your tractor with loader will be pushing 3000.
Get a Tekonsha proportional brake controller.
   / not sure what trailer to get. need some help #4
I've got a Quality brand 16' (plus 2' dovetail) 7,000# tandem axle. It weighs 2400 empty. Recessed ramps that pull out from under trailer so that they're not in the way like the flip up type would be if I have an implement on your 3 point.
It also has a pressure treated 2x6 deck. It works just fine for the Kubota B3030 cab with LA 403 loader. Before that I had a JD 790 with 419 loader that it hauled around with no problems.
   / not sure what trailer to get. need some help #5
Just don't under buy in length and capacity if you even think there is a chance of a larger tractor in the future. I'd also say buy longer if than the you need so you can adjust where you your tractor will sit so you can adjust the tongue weight on the truck when needed. Something like a bush hog requires more room than the box blade you are presently going to haul.
MarkV
JOHN DEERE 9650 COMBINE (A51247)
JOHN DEERE 9650...
2016 JOHN DEERE 3032E LOT NUMBER 94 (A53084)
2016 JOHN DEERE...
2007 Ford Escape XLT SUV (A51694)
2007 Ford Escape...
CFG Industrial SAII100 (A50123)
CFG Industrial...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
