Not sure what I want for a trailer
   / Not sure what I want for a trailer #21
the reason I like electric brakes is because if you loose tow vehicle brakes, you can still use the trailer to come to a semi controlled stop.. hard to do with surge brakes.. :(
though I'd take surge brakes over no breaks if I had no other choice..
soundguy
Agreed. And if you have to traverse steep hills...I mean really steep. Sometimes with gravel, surge breaks don't cooperate. If you get into a position where the truck loses traction, the surge breaks don't help..I've been there. The simple fact that there is no manual control from the truck is what I don't like. Most newer trucks come with a 7 pin connector, and the controllers are plug and play. So why bother with surge breaks?
Also when running on the interstates, semi's can blow you around. A touch on the controller will straighten you right up. Have to "spike" the brakes on a surge set up. I see no upside with them. But then again, just my uneducated opinion.
Personally, I wouldn't take one for free unless I could change it over to controlled brakes.
   / Not sure what I want for a trailer #22
I agree.. i see no upside as well. I've used the panic button to stop a fishtail when a large wind blew me near off the road once.. surge brakes and I've have been int he ditch facing the wrong way.
surge brakes can be fine when you leave the house then fail 5m downt he road from a leak or seal... at least with electric.. it usually goes til the magnet fails or the brakes wear enough to need repalcing finally.
soundguy
2019 BOBCAT T870 SKID STEER (A60429)
2019 BOBCAT T870...
2017 VOLVO VNL64T TANDEM AXLE SLEEPER TRUCK (A59905)
2017 VOLVO VNL64T...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
UNUSED SDLANCH SDLWC WOOD CHIPPER (A60432)
UNUSED SDLANCH...
