Not stuck 165D hydraulic issues
   / Not stuck 165D hydraulic issues
Can't open attachment. So, I have had the lever stick and then the bucket will lower normally, but will keep going downward until the front end lifts up. So I have to shut tractor down to get it unstuck. When I get it unstuck, it goes back to moving slowly downward
   / Not stuck 165D hydraulic issues #12
Ok, thanks! If I have time before work tomorrow, I will give it a try
   / Not stuck 165D hydraulic issues #14
Looking at your pictograph it looks like as you push your boom lever ahead you should get into a power lower which would lift the tires as it powers the boom down,
if you push it further ahead you should go into a "detented" float position which would allow gravity and ground to float your boom up or down with no hydraulic force.
The detent control is usually located in a cylinder style enclosure on the far end of the valve spool. Those can be removed and cleaned, as they can accumulate dirt and rust and other garbage.
Just be aware that most of them contain springs ( for self centering) and balls to snap into a groove with springs for the detents.
So, would that be the long orange cylinder on the backside of the boom valve?
   / Not stuck 165D hydraulic issues #16
I would expect so, that's were all the ones I've had to take apart were.
Ok, wasn't able to get to it today. Hopefully tomorrow
I got it figured out.
   / Not stuck 165D hydraulic issues #19
Surely you are going to tell us what you figured out!
It really isn't a fix, as there is still an issue. But, when I lower the bucket and it sticks and I let it go all the way down until it stops or lifts the front end, I have to tap on the lever with a hammer to get it unstuck. However, if I lower bucket and if I pull back on lever rapidly, it will not stick, but I can feel where it catches. If this all makes sense
2017 WEILER P385 ASPHALT PAVER (A52709)
2017 WEILER P385...
1993 Generac Olympian 93A 100kVA Towable Diesel Generator (A56857)
1993 Generac...
2017 Chevrolet Tahoe SUV (A56859)
2017 Chevrolet...
2014 KOMATSU D51PXi-22 CRAWLER DOZER (A52709)
2014 KOMATSU...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
2005 International 5900i T/A Flammable Liquid Transport Truck (A55973)
2005 International...
