not engaging in forward or reverse
/ not engaging in forward or reverse #1
Eric Blanchette
antioch ill
L110 john deere tractor
changed a flat rear tire and now the tractor will not engage in forward or reverse on ground level. when jacked up the tire spines. I am confused and at my wit ends wondering how to fix this.Grass getting to long..Please help.
This a john deere L110.
/ not engaging in forward or reverse #2
Sounds like you pulled out the free wheeling lever when you changed the tire ---- push it back in ---- or at least check it. It's that thing that looks like a wire sticking out of the rear frame.
/ not engaging in forward or reverse #3
If it isn't the free wheeling lever, then as mentioned in another post, probably the key that slides in the slot in the axle dropped out, and wasn't noticed when putting the wheel back on the axle. It is about 2" long and 1/4" square, or close to that.
If it is lost, it is part no. M82401
John Deere Gator TX4x2 (A62177)
John Deere Gator...
1998 VOLVO AUTOCAR WATER WELL DRILL RIG (A65643)
1998 VOLVO AUTOCAR...
Spartan RT-HD Zero Turn Mower (A66285)
Spartan RT-HD Zero...
International 154 Cub Lowboy, Gasoline, 60" Mower  (A62679)
International 154...
John Deere Planter (A62613)
John Deere Planter...
1992 CHEVY 1500 CUSTOM (A65643)
1992 CHEVY 1500...
