Not another oil thread!
/ Not another oil thread! #21
_RaT_ said:
How do you get rid of the old air?
Vaccum pump. I suppose it is considered hazerdous material now.
/ Not another oil thread! #22
Atmospheric air is about 75% (by weight) Nitrogen, 20% Oxygen and 5% other gases including such as Argon. Nitrogen has an atomic number of 7. The atom has seven protons and seven electrons. Oxygen has an atomic number of 8; eight protons, eight electrons. For all but precise Physics and Chemistry calculations there is no appreciable difference in molecule sizes. The "Ideal Gas Law", "Charles' Law", "Boyle's Law" and one other I can't remember, are universally applied in calculations concerning volume of gas at specific temperatures and pressures. For practical purposes, all common gases expand the same amount with heat, they all react the same with changes in pressure.
In summary:
  1. Nitrogen is no more heat stable than atmospheric air.
  2. Nitrogen will leak through the same hole as Oxygen or atmospheric air.
  3. My Chemistry instructor must have been really good to make me remember this stuff for 30 years!
  4. P.T. Was right!
(However, Nitrogen is pretty much inert so it won't rust your wheels:) .)
/ Not another oil thread! #23
Sorry guys! I didn't mean to get this thread off track like this. Seems it started with something about daily oil changes...:rolleyes:
/ Not another oil thread! #24
Nitrogen molecules have a larger diameter than oxygen.
Nitrogen - Wikipedia, the free encyclopedia
"Nitrogen molecules are less likely to escape from the inside of a tire compared with the traditional air mixture used. Air consists mostly of nitrogen and oxygen. Nitrogen molecules have a larger effective diameter than oxygen molecules and therefore diffuse through porous substances more slowly."
Why Inflating Tires With Nitrogen Makes Sense
" Over time the pressurized air inside a tire slowly migrates and permeates its way into and through the tire. Air contains moisture. So in addition to reducing the tire’s inflation pressure, the oxygen and moisture in the air reacts with the rubber compounds in the tire, causing them to break down and lose their strength and durability. A chart is available illustrating that nitrogen is the slowest of all gases to flow through a permeable barrier such as a tire. For a copy of the chart please contact us at the number or email address shown below.
An underinflated tire is much more prone to premature failures. That’s because when underinflated, as a tire rolls, it flexes more than it was designed to. This flexing bends the tire’s rubber and steel (used within the rubber to provide additional operating characteristics) and generates heat. Heat is a tire’s worst enemy and accelerates tire wear dramatically. There is a direct correlation between how much a tire is underinflated and how much faster it wears.
Since air, which contains oxygen, is not an inert gas, it is affected by changes in temperature, which affects the rate of air loss from a tire. The air inside a tire expands when heated and contracts when cooled. More air is lost in hot weather. The consensus is that for every 10-degree Fahrenheit change in temperature, there will be a one psi (pound per square inch) change in the pressure of a tire. Nitrogen will not fluctuate as much. Being an inert gas - not readily changed by chemical reaction, nitrogen provides constant pressure and is less susceptible to accelerated diffusion caused by changing temperatures.
Nitrogen inflation minimizes moisture and oxygen in a tire so there is less rubber degradation and no corrosive properties as found in compressed air. A reduction in rubber oxidation slows a tire’s “aging,” improving the casing’s structural durability, lengthening its useful life and yielding a higher proportion of retreadable casings that can survive more retread cycles. All of this helps lower operating costs. Some fleet managers, who had been dead set against retreads, are now willing to use retreads with nitrogen inflation.
Because nitrogen molecules are slightly larger and less permeable than oxygen and all the other gases in air, it migrates considerably slower through a tire. It might take a truck or bus tire inflated with nitrogen about three months to lose two psi, whereas even a well-maintained tire inflated with compressed air will lose, on average, about two psi per month. "
/ Not another oil thread! #25
Don't mind us, were just passing gas. :D
/ Not another oil thread! #26
Hey Rat, ain't it funny how a joke can turn so serious...:)
/ Not another oil thread! #27
Rebel said:
I didn't think Mobil1 was Diesel rated???
"Mobil 1 10W-30 exceeds warranty requirements for gasoline engines where an API certified oil is specified. It meets:
ILSAC GF-4 (API Certified - Starburst)
API SM/SL
GM 6094M/GM4718M
Requirements for Diesel Powered Vehicles where an API CF or API CD is Recommended
ACEA A1/A5, B1/B5 "
Taken from...
STORGE SPACE WITH MISC ITEMS (A67714)
STORGE SPACE WITH...
BRIGGS & STRATTON PORTABLE AIR COMPRESSOR (A64276)
BRIGGS & STRATTON...
Fuel Storage Tank (A68134)
Fuel Storage Tank...
VERMEER V430 TRENCHER (INOPERABLE) (A67714)
VERMEER V430...
CULVERTS (A68842)
CULVERTS (A68842)
2002 Pace American of Texas Trailer, VIN # 47ZA528212X020330 (A61572)
2002 Pace American...
