Not ANOTHER grapple
/ Not ANOTHER grapple #1
Jeepnford
NE Missouri
Case DX35
Here is a grapple I built for a friend. You'll likely notice it has a bit of an overbite. I built it using my bucket as a guide and his is a little different. Anyway, from those that have used one similar to this, is there any reason I should trim the tines? Or leave them as is?
/ Not ANOTHER grapple #2
Mine is set-up to "grip" the bottom;I can pick up a 1/2''thick rock.I also have a tooth-bar on my bucket.Handy tool for sure.
/ Not ANOTHER grapple #3
Basically - my answer is - NO, don't trim the tines. If you are going to trim the tines - leave them long enough so the bucket can be rolled forward and the tines can still be used to back drag. I find back dragging with my grapple a VERY effective way to gather up small things - pine straw, limbs, brush etc.
/ Not ANOTHER grapple #4
oosik- is your grapple built heavier than the OP's grapple?
I can see how backdragging with the grapple tips would be useful for gathering small materials, but I would think that it will put a great strain on the grapple linkage if you hit something fixed (like the top of a root). Also if you ever turn the wheel and backdrag at an angle, that would really stress the grapple "teeth".
OP- It might be good to warn your friend about the risks of backdragging and let them decide whether to trim the teeth or leave it "as is". Very good work- looks factory made.
/ Not ANOTHER grapple #5
Yes - my grapple is a Land Pride SGC1560 and considerably heavier than the one that the OP built. However - as long as you are back dragging light stuff it should work just fine. BTW - that is a very nice looking bucket grapple. If the grapple is used to back drag with the tines in a relaxed/forward position rather than an aggressive/rearward position - nothing will be caught in the tines.
Even with my HD grapple I do not back drag with the tines in an aggressive/rearward position.......... with the tines in a forward position they will just bump over anything hard or fixed.
/ Not ANOTHER grapple #6
My Gorilla Grapple has a serious overbite, very handy:
/ Not ANOTHER grapple #7
Mine doesn't have quite that much overbite - but any you can get proves out to help.
View attachment 500202 I particularly like that last pic, XFaxman, where the grapple has spit out the concrete chunk
like a cherry pit.
Well, he decided to have me trim the teeth, so that's what I'll do. Thanks for the suggestions and the compliments. XFaxman I was buying some steel pipe from a scrap yard and the had a heavy grapple similar to yours on a skid steer for moving steel. I couldn't believe how much they had bent it
/ Not ANOTHER grapple #9
like a cherry pit.
:laughing:
If that was spitting out a cherry pit, what is this?:
2018 CATERPILLAR 320GC EXCAVATOR (A60429)
2018 CATERPILLAR...
429858 (A61165)
429858 (A61165)
(INOP) 2018 FORD EXPLORER (A59823)
(INOP) 2018 FORD...
(4) METAL DRUMS (A63291)
(4) METAL DRUMS...
UNUSED WOLVERINE HYD STUMP GRINDER (A64281)
UNUSED WOLVERINE...
2024 DODGE RAM 2500 HEAVY DUTY PICKUP TRUCK 4x4 (A59912)
2024 DODGE RAM...
