NorTrac Tiller
   / NorTrac Tiller #1
Ed_B
Wisconsin
FarmPro 2425
Hello All:
I posted this in the Attachments discussion, but since you guys have been so helpful in the past, I thought I would try here too.
Here goes:
I bought a 47 in. NorTrac Tiller from Northern Tool. I need replacement tines. The factory tines are cast iron, very brittle and break pretty easily. Any ideas for a replacement set made out of steel? Or if I can't get steel how about the original cast iron ones?
Thanks in advance.
Ed.
   / NorTrac Tiller #2
Have you tried AgriSupply.com ? They might have something generic that could be made to work, if you know the diameter of the shaft.
   / NorTrac Tiller
Hey Ron:
Thanks for the help but. . .
I looked there at Agri Supply.
The tines are individual tines that bolt onto slots on the shaft. Each slot on the shaft has a hex cutout on one side where the head of the bolt fits into and a hole that the bolt fits through to hold the tine. You then stick the tine into the slot and bolt through the tine/slot. There is a lockwasher and nut on the other side. I think there are 38 tines on the shaft. I see other designs like King Cutter and the newer Jinma have a different configuration than mine. Northern Tool discontinued the 47 in.
   / NorTrac Tiller #4
Your tiller is set up like the grey market rice tillers. I have had similar experiences w/broken tines on my grey market tiller. In the future I would suggest to always break hard clay and similar soils first with scarifiers, plow etc. before attempting to till using this type of tiller. I loaned mine to a "buddy" and when I got it back it had 3-4 tines left on it. I lucked into a set of tines I stumbled across while stopped a tractor dealer in Missouri, he had about 45-50 of them in a scrap pile and couldn't even remember where he had gotten them. He handed me 2 five gallon buckets and told me to take them and refused for me to pay him for them ( I left $50 bucks on the counter when I left though). Prior to that I had little luck finding them at an affordable price but try these guys.
ADAMS EQUIPMENT CO.
or
Yanmar Tractors -- Parts -- Sales -- Service
   / NorTrac Tiller
Hello All:
For fututre reference for you guys, I found some Yanmar tines that will work. $189 a set at hoyetractor.com., I got the info off of a January, 2008 post.
Thanks for you help.
Ed.
   / NorTrac Tiller #6
Try Tillerblades dot com, they have some blade and have a sketch showing hole dimensions. I think their inventory is limted. I've bad luck with the rice tiller design also. I rebuilt my tiller with a new shaft to take the two bolt flange design and now use the King Kutter tines. bjr
Massey Ferguson 9250 (A53472)
Massey Ferguson...
SCAN FOR HAULING AND FINANCING INFORMATION (A51246)
SCAN FOR HAULING...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
BUYERS PREMIUM & PAYMENT TERMS (A53426)
BUYERS PREMIUM &...
RYOBI 2900 PSI GAS PRESSURE WASHER (A51248)
RYOBI 2900 PSI GAS...
RYOBI 3300 PSI GAS PRESSURE WASHER (A51248)
RYOBI 3300 PSI GAS...
