Snow Equipment Owning/Operating Normand Hybrid and R4 Traction
   / Normand Hybrid and R4 Traction #21
I do clear my shared drive which is 350 yards long and paved and clear my 4 other neighbors' driveways. Next year I will be soliciting contracts with the adjacent neighborhood and will be traveling down the road a bit. You got me thinking about the 3 point top link. I found an air over hydraulics top link called Hydraulink. Can't seem to find anything current for them. The device would basically ad a shock absorber to my top link without the use of my tractor hydraulics. It seems a Cat2 version is sold at Northern Tool. Do you know anything about them?
Read through these threads....it is talked about:
https://www.tractorbynet.com/forums/attachments/174498-hydraulink-self-contained-air-over.html?highlight=hydralink
https://www.tractorbynet.com/forums/hydraulics/420726-conversion-toplink.html
   / Normand Hybrid and R4 Traction #22
I値l just add that I really like your blower. Very nice, wish I had one.
   / Normand Hybrid and R4 Traction #23
There are always chains,
the issue i have found with the 3000 series front r4's is finding good ,durable chain, it seems to be an odd size. Where did you find yours?
I have found 2 link to be far preferable to 4 on pavement, smoother and less likely to mark as they don't slip then grip like 4 link
You can use ATV chains on your front tires,
ATV-UTV Tire Chains | Free US Shipping
The diamond pattern chains will provide more traction and a smoother ride then either 2 or 4 link spacing or the H pattern or dual grip style.
They also maintain traction continually instead of a grip and slip as the ladder chains do.
I have seen much less pavement marking from them then ladder chains,
   / Normand Hybrid and R4 Traction #24
Lou,
thanks for the link and the idea, i'll take a look
Really need something better on the rear as well. I need to use 4wd or i slide with the blower scraping. maybe it would not happen with the loader off but with it on i have to have front assist or i'm not going anywhere.
On another note, i had needed a new scraping edge as the original had worn(i believe it was just mild steel- A local metal shop fabbed one up for about 40% of the cost of a factory hardox edge.
The replacement is an AR steel so it should last a lot longer
QUOTE=LouNY;5621065]You can use ATV chains on your front tires,
I have seen much less pavement marking from them then ladder chains,[/QUOTE]
   / Normand Hybrid and R4 Traction #25
Lou,
[/QUOTE]
There are many of the "euro" style chains which while expensive will provide amazing traction and a good ride,
AquilineTalon, the TRYGG, and OFA brands are all very good.
I run the Talon type on two tractors, and we have them on 3 over at the farm.
They grip so well that the traction is excellent and the ride is good.
   / Normand Hybrid and R4 Traction #26
well, that didn't work out- they don't have anything for a 27x 8.5x15
I'll try calling on monday maybe something can be altered
Tempted to switch to radial turfs when these tires are done
   / Normand Hybrid and R4 Traction #27
I would not swear to the exact fitting but to me the 27 inch tire diameter and the 8.5 width are the sizing consideration for chains.
If I was getting chains for that tire I would look at the chains for the OD and width as the rim diameter is a minimal consideration for chains.
With an R4 having a squarer profile then an ATV tire I would consider chains for 27x10 tires.
Towards the bottom of this page are some that might be a good fit,
ATV-UTV Diamond Back Studded U-Grip Tire Chains| Free US Shipping
God luck
Lou
   / Normand Hybrid and R4 Traction #28
Thanks lou
just the kind of info i was looking for
God luck
Lou
PROTEMP 175,000 BTU HEATER (A52708)
PROTEMP 175,000...
167 (A52708)
167 (A52708)
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
2018 Chevrolet Silverado 2500HD Crew Cab Service Truck (A56858)
2018 Chevrolet...
LOT OF FIRE EXTINGUISHERS (A58374)
LOT OF FIRE...
2019 CATERPILLAR 305.5E2 CR EXCAVATOR (A52709)
2019 CATERPILLAR...
