Oil & Fuel "Normal" temperature on gauge L3400D
   / "Normal" temperature on gauge L3400D #1
Kubota L3400
Temperature indicator used to sit around the middle of the gauge. Last year I tightened the fan, flushed out the coolant and replaced it, just regular maintenance. I've noticed that now the temperature gauge indicates maybe 1/8th at hottest, summer or winter. Don't know if it was the flushing or what. Everything seems OK but is low indication normal? Do I need to change the thermostat? Anyone else seen this?
   / "Normal" temperature on gauge L3400D #2
My L3200 sits at 1/4 on the thermostat most of the time. Pushing it to the limit with the tiller on the PTO will heat it to 50%. I believe our tractors are almost the same a generation apart with only trivial changes.
   / "Normal" temperature on gauge L3400D #3
My L3400 DT BOTA runs cool even on the hottest of SW Fla days. Might jump up to 1/4 temp gauge reading.
IMO your temp guage is working fine. I always kidd folks that if I moved to a real cold climate I'd have to block up the front air restriction flow to get guage to rise some.
   / "Normal" temperature on gauge L3400D #4
Up here in the frozen north that is exactly what I do. On a cold day you will not get the engine up to temp unless you do.:eek:
   / "Normal" temperature on gauge L3400D #5
Something has changed.
A thermostat check or change would be in order.
Nothing you did would likely be the cause of your low guage reading.
A thermostat change is neither difficult or expensive,and your engine wants to be run at full temperature for best engine life and fuel efficiency.
A quick check on cars and equipment is to run a cold engine 3-4 minutes under load,grab the upper coolant hose and feel the temperature.
The hose should still be cool-if warm,the coolant is passing the thermostat as the engine has not yet warmed up enough to open the thermostat.
Hope this helps-Good Luck!
   / "Normal" temperature on gauge L3400D #7
I don't think you have a problem... my L3400D with 100 hours on it is exactly the same way, and runs perfect.
Thanks for all the feedback. Makes me feel secure.
   / "Normal" temperature on gauge L3400D #9
i. Did. The same. With. Mine. Now. It. Runs. Right on. The red. All the time. What. Happened.
   / "Normal" temperature on gauge L3400D #10
Mine runs just above the small tick mark on the temperature gauge, maybe 1/4? Only time it goes above that is if the radiator screen gets clogged with chaff.
2025 Kivel 24in Forks and Frame Mini Skid Steer Attachment (A50322)
2025 Kivel 24in...
2003 Ottawa Spotter Truck (A50120)
2003 Ottawa...
Wolverine Slide on Manure Forks (A50515)
Wolverine Slide on...
UNUSED FUTURE SKID STEER 4IN1 COMBO BUCKET (A51244)
UNUSED FUTURE SKID...
2014 CATERPILLAR 740B OFF ROAD DUMP (A51242)
2014 CATERPILLAR...
