Oil & Fuel Normal Oil Leakage?
   / Normal Oil Leakage? #1
Calvin
I use the tractor on hills quite a bit, so it moves around at all angles (all those that work w/o tipping over...) is the oil on the top of the case normal? No leaks under the tractor. Maybe the tops of the cases are not sealed as well as the sides? Is this normal or should I reseal these places?
   / Normal Oil Leakage? #2
What tractor is this about ?
This is for a Dong Feng tractor
   / Normal Oil Leakage? #4
I would wash the dust off and keep on using it. You may try to check the bolts to see if they are snugged down.
   / Normal Oil Leakage? #5
probably wouldn't hurt to add a lil sealer to each bolt on the top if they are leaking past the threads.. might be rough castings with 'generous' thread space..
check that shifter boot to see that it seats well too.
most trans sling oil all around a case.. after a good day working not uncommon to see oil migration past loose bolts or bad boots... if you are on side hills and angles alot.. then it's even more normal I'd say..
soundguy
   / Normal Oil Leakage? #6
Heck, there is just enough getting out to keep things from rusting!:D
Probably more trouble than it's worth to get everything seal to leak proof status.:D
   / Normal Oil Leakage? #7
Now that is funny but true!!
I would not consider that a "leak". Check bolts, go on with life!!
Deano
Thanks for the replies. I tightened the bolts a bit, but they did feel ok. Nothing obviously loose. Will see what happens. Just wondering if others experienced this sort of thing also.
   / Normal Oil Leakage? #9
Deano
Oh yeah, we could get into a real serious discussion of what constitutes a leak, weep, seep, wicking, etc, but its not worth the effort. It does seem that a lot of equipment develops a dust attracting film of something. ;)
   / Normal Oil Leakage? #10
Hard to see where its coming out from but ive had great luck with this
Seal-All Contact Adhesive 1208
from wal mart like under 2 bucks a tube
maybe a layer of this around the casting mating surfaces will help.
2012 Freightliner Cascadia (A61306)
2012 Freightliner...
UNUSED FUTURE FT-GB200-79"X71 1/2"-1" STEEL PLATE (A60432)
UNUSED FUTURE...
2001 JOHN DEERE 310SG BACKHOE (A60429)
2001 JOHN DEERE...
2017 Wacker Neuson LTV6 Towable Light Tower (A56857)
2017 Wacker Neuson...
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
MINI KID DIRT BIKE (A56859)
MINI KID DIRT BIKE...
