noob snowblower question
   / noob snowblower question #2
Anything labeled "shearbolt" I see #19 on page 12 of that manual.
   / noob snowblower question #3
I have owned this type and size blower, a good machine. Keep spare shearbolts and nuts on board. I went full years without breaking one, then broke one every 3 hours for a while. So whatever the book says, have them in the correct grade. Keep the wrenches in your tool box too.
   / noob snowblower question #4
Item 71 on page 21 of the manual....shearbolt for the pto shaft. If you are already breaking them, I would drill it out to a 1/4" which is only .014" larger and use a grade 5 bolt about 1 5/8" long.
   / noob snowblower question #7
i guess I'm lucky, only broke 1 shear bolt in 14 years and thats because I tried to snowblow 2 inch layer of ice.
   / noob snowblower question #8
If the blower is brand new, let it run on the tractor for a 1/2 hour, then grease it up again. New assemblies take a little time to wear in, shearing bolts would be reduced. Don't put a higher rated bolt in, it just moves the failure to another shear bolt that will be harder to access. Engage the PTO with the blower lowered, doing it while raised puts additional stress on the PTO shaft shear bolt.
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
1996 Stoughton Semi-Van Trailer (A50860)
1996 Stoughton...
UNUSED 2-Pack Blue Ratchet Strap Set (A50860)
UNUSED 2-Pack Blue...
UNUSED U Bolt Wire Rope Clamp Set (A50860)
UNUSED U Bolt Wire...
Jayco Jay Series 15ft S/A Pop Up Camper (A48082)
Jayco Jay Series...
2024 iDrive TDS-2010H Pro Jack M2 Electric Trailer Jack System (A48081)
2024 iDrive...
