Non-powered brush cutter?
/ Non-powered brush cutter? #1
timrob
Anybody know if there's a non-powered brush cutter that my ATV could pull? I was considering buying an Amish farm for hunting. It's trails are already cut, they just need to be cleaned up a couple times a year. The Amish use something that's horse drawn, so I was hoping there was something my ATV could pull. I didn't want to spend $1000 on a gas powered one.
/ Non-powered brush cutter? #2
The Amish also know how to use whet stones to keep their tools sharp so it doesn't take as much effort to cut through things manually.
As for the rest of us schlubs, we can still tear through tall grass with the blade on backwards thanks to gas powered engines!
Sorry, that's probably not much help to you.:eek:
/ Non-powered brush cutter? #3
you will probably need a self-powered trail mower (swisher makes one Swisher Mower & Machine Co.: Products: Trail Cutters) they generally have a 12-18 hp engine that spins the blades and they adjust to pull behind something or they can be offset to the side, TSC has them for 900-2000, they can be had used (craigslist) for 500-1500 in my area.
HTH
Aaron Z
Aczlan,
If the trail is only grass and weeds, no saplings or anything heavy, would you say I would probably still need a self-powered mower? I'm not looking for beauty, just so it's easier to walk through while hunting.
/ Non-powered brush cutter? #5
HTH
Aaron Z
I'd rather have a 3 point hitch mounted push mower.
/ Non-powered brush cutter? #6
timrob said:
Aczlan,
the mower has to get its power from somewhere, so (as I see it) there are two ways to have a tow behind ATV mower:
First: Ground powered, as far as I know there are two options: an older ground powered sickle bar mower, one of those might work, you would just need to remember that they are generally setup as offset mowers and that might not work too well on a trail.
or a towbehind gang of reel mowers (like this one: The Gang of Three ) however if I remember correctly reelmowers have problems with heavy stuff... they are better on grass so that might not work.
the biggest problem with using ground powered equipment is that when you hit a patch of heavy stuff it will clog, whereas with selfpowered equipment you can slow down and let it chew its way through it.
Second option: Selfpowered. for self powered equipment there are three options: first, store bought (ie: swisher). I dont know where you live but in minneapolis there is a 44" swisher on craigslist for $250 Swisher 44" Tow Behind Mower so there are out there, just keep an eye out and when one shows up, jump on it.
the second option is to make a gang of push mowers like this: Backyard blitz for mower man | NEWS.com.au (also a recent issue of the farm show magazine had a couple of good ones)
the advantage is that they are cheap, the disadvantage is that you then have 3-5 more engines to maintain.
the third option (which I am using to add 2' to the cut of a lawnmower) is to get a wide walkbehind mower (I have a Ariens 7/24 snowblower/mower which has a 30" mower deck on it, the snowblower comes off and a mower goes on) and make a hitch to tow it behind your ATV, I will take pix and post them next time I put the hitch on. it has cost me ~$250 so far including buying the snowblower last fall.
HTH
Aaron Z
The backyard blitz was awesome. I wonder how well it really works.
You gave me some good ideas. I really didn't know where to look before.
For your third option, pics would be great. I'm already going to spend a pretty penny on the land, $250 sounds about right.
/ Non-powered brush cutter? #8
if you have an extra 8hp briggs engine i have a 48"motts hammer mower it needs an engine but everything else is in good shape all you have to do is figure out how to get it from my house to your's.i'm going to the scrap yard in about 2 weeks with a load of iron so if you are anyone else is interested let me know real soon.here's a picture of it.
The Gang of Three Looking at the picture, do you think the 3 mowers can rotate individually or the whole setup can only rotate at the hitch?
EDIT-Never mind, I looked at the tiny illustration and it's fixed.
TOMMYHPX4X4,
I'm in Michigan, so that's a little far. I'll have to take a look at Craig's list like Aaron Z. suggested.
/ Non-powered brush cutter? #11
I was driving past a neighbor's at the farm a few weeks ago. He had some interesting "iron" attached to tractor in the pasture. I couldn't resist it, I had to go see. It was a 6' bush hog built out of a truck rear axle and differential. There were actually 2, one directly behind the tractor and one offset to the right and overlapping the first. When I talked to him he said he had five of them and that he bought them years and years ago from some old rancher down in South Texas who built them from rear axles left over from WW11. The differentials had forward, reverse and neutral positions and the speed of the blade was controlled by the towing speed. He said he had five of them and could cut a 30' swathe if necessary but only in long, straight pastures as turning all that lot around was a real pain. :)
I watched him run them and they worked great. Ofcourse there were no deck or guards on them, just the wheels, axles and blades. It looked kinda scary but when he stopped the tractor the wheels stopped and the blades stopped.
It made you wonder about the ingenuity of some of those old farmers.
/ Non-powered brush cutter? #13
EastTexFrank,
Years ago, maybe thirty, there was a farmer down here that had one same or almost simular as what you stated. I remember it well, for when he stopped the tractor, the cutting blades also stopped. I've done forgot all about them contraptions. From what I remember, they cut his pastures really well ..... The cutter was some kind of heavy duty !!!!
Thanks for sharing >>>>
~~~~~~ jamie
/ Non-powered brush cutter? #15
Just remember that anything self powered or ground driven is going to mess you up if you are knocked from your bike .
In regard to rough country mowers , something like this may suit you other guys .
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
2015 Kia Sedona Van (A61569)
2015 Kia Sedona...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
Vertical Steel Well Tank (A61570)
Vertical Steel...
