Noisy Tach Cable?
   / Noisy Tach Cable? #1
wsp617
Wisconsin
JD 1070
This the first year I've owned my JD 1070. I haven't run it in awhile and I got it started the other day when it was COLD (6 degrees). There is a whining or squealing that sounds like it's coming from the dash area and the tach needle is jumping. I'm guessing it's the tach cable. Is this a common issue? Is it a cold weather issue as it never did it all year. Is it something that can be lubed?
   / Noisy Tach Cable? #2
Yes it can be lubed take the end off at motor put some graphite in like you would use on a lock.
Usually the spiral will pull it up the tube and lube it self.
Their might be as lube JD recommends call a dealer and ask.
tom
   / Noisy Tach Cable?
OK, Thanks.
I'll try the JD dealer tomorrow.
2011 Ford Escape XLT SUV (A55853)
2011 Ford Escape...
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
2019 FREIGHTLINER CASCADIA TANDEM SLEEPER TRUCK (A54607)
2019 FREIGHTLINER...
Forklift Safety Basket Attachment (A55787)
Forklift Safety...
PETERSON 5000H WHOLE TREE CHIPPER (A52705)
PETERSON 5000H...
