Noisy Hydrostat/Hydraulics?
   / Noisy Hydrostat/Hydraulics? #1
e.myers
Springhill, SC
Kubota L4400 4WD Hydrostat
Just got a new L4400 Kubota with hydrostat and FEL.
Hydraulics seem "noisy" to me... but not sure.
Was wondering if it's possible that when they put the FEL on, something got air in it and is causing the noise.
Currently have 5 hours on it and intend to put another 12 on it today.
Running rotary tiller on it and it's pretty much wide open all day....
Do I need to worry about this?
Do your hydraulics kind of squeal/grunt... kind of high pitched type noises.
Anyone know how an auto tranny sounds when it's about to go out? Sounds kind of like that....
Fluid level is fine.
Just want to make sure I'm not tearing something up.
   / Noisy Hydrostat/Hydraulics? #2
HST trannys are a bit whinny about working kinda like a teenager. I think the owners says not to run the engine wide open for the first 50 hours. It will make more noise in high range than low or mid range. The whine also varies with the load. If that s what its doing its all normal.
   / Noisy Hydrostat/Hydraulics? #3
Just run it according to break in procedure in owners manual. Make sure you've got correct fluid level and if it has hydrostatic fan its not blocked. Check you coolant level in radiator. They sometimes arrive low regardless of how wrong that would seem.
After checking that out and with what previous poster said and you've got a warranty, just run it. I bet it will quite down.
   / Noisy Hydrostat/Hydraulics? #4
When you park it, after a few hours of work, do so on a surface that would easy to detect any leaks. Park it, if you can, on clean dry concrete.
After 12 hours, inspect the concrete for spotting of hydro fluid. This is merely a safeguard. My tractor was REALLY noisy when I got it. I accepted it, with gritted teeth, as "normal".
I regret to say that my Kubota came with a very loose hydro line fitting and it was allowing seepage of fluid that I could only have detected by parking it in my clean shop. (editorial- clean by my standards, not my wife's)
I tracked down that leak, found the loose fitting. It clearly was sucking air. After tightening it, my hydro whine was decreased by 50%. This is just a suggestion and may not fit your situation at all.
OK guys. Thanks.
I actually read the manual before using the tractor and saw the part about break in.
Oh well, normal break in procedure didn't/couldn't happen. Needed to get the property tilled up so I could get seed in this weekend.
That requires pto speed 540 RPM's which requires basically a wide open tractor.
Really now, how many functions are there for a tractor that you don't need to get the R's up way high.... other than just joy riding (and front end loader work possibly).
Well anyway, I have 15 hours on the tractor now. Noise might have been better today(or maybe I'm just getting use to it).
The symptoms you describe sound like what I'm experiencing.
I'll check for leaks too.
Eddie
   / Noisy Hydrostat/Hydraulics? #6
I posted similar concerns about my B3200, everyone assured me it was normal. I ask my delivery guy about RPM and he said keep it around 2000 at first. That is only 200 less that PTO so it has not been to difficult. From a mechanical point of view I don't exactly see why it would matter.
Russ
Wait a minute.
Am I missing something?
My PTO speed (where the triangle is on the tach) and the recommended PTO speed for my tiller is 540rpm's.
To get to that triangle on the tach is almost wide open on the throttle.
To go the speed that I needed to travel, I needed to be in low range.... so tractor was running basically wide open.
Was I doing something wrong or "stuuuuuuuuupid"? Tractor never came close to running hot the whole time and only bogged down when I got in real deep stuff with the tiller set all the way down.
Ruralruss-
So to get to 540 RPM's on your pto, you only have to be at 2200 rpm's?
   / Noisy Hydrostat/Hydraulics? #8
Wait a minute.
Ruralruss-
Not in the seat right now but I think it is 2200 or 2300 RPM. I think the tack goes up to around 3000 rpm. Of course I have a different tractor than you. I am not for sure you need to worry. I remember way back there were always break in rules for new cars. But there were not the same between auto makers. I was always told to break it in the way you normally drive. Almost everybody said don't drive at a constant speed for a long period. My manual says the parts of the engine are not familiar with each other, got love that translation. I would say if you had to work it hard right off then do you first 50 hr. service at 45 hours or something.
Russ
   / Noisy Hydrostat/Hydraulics? #9
HST is exceptionally durable transmission.
It will make noise... higher RPM and load = more whine.
Proper speed range selection will assist in whine reduction (L/M/H). Try a lower range, if available, to see what I mean.
SUDT hydraulic oil is reported by some, myself included, to slightly reduce the whine.
However, UDT is just fine for most climates. Extreme cold is where it shines.
I run at about 2500RPM to get to PTO speed.
I run this speed seldom... only when I actually have a device on the PTO or when working vehicle very hard (very heavy lifting, plow in the ground, etc.)
Net... with some experience, you will get more used to the whine, then begin using it as an in Indicator of engine loading and when to back off the rocker pedal and/or move to a lower gear or seek more RPM's.
Enjoy your new tractor, sounds like you are using it for its intended purpose:D
   / Noisy Hydrostat/Hydraulics? #10
Misery loves company.
I too put my new 'Bota to work pretty much right away. I did not red line the tach, or anything close, but I was certainly above putzy speeds. I had work to do and work for which I had bought the tractor. I varied the rpms between 2300 and 2800 never holding it steady for more than 5 minutes, best I could do to "break it in" but still, just went about the work. I had sod to bust, a heavy trailer of dirt to load and pull, multiple times too. I had a driveway to rake. You get the idea.
Like you, there wasn't an opportunity to just cruise around gently or parade about the lane getting a dozen gentle hours on it.
Someone mentioned changing out your fluids early, and I see that as a good thing. So, here is what I am going to do. I have decided to go ahead and do my 50 hour service at 25 hours, which will be in a week or two. I'll get the metal shavings out, get fresh, clean oil and fluids in. It will be just fine.
Besides, calculating ahead, I don't feel like doing my 50 hour service in January anyway. With my luck, it would minus 20 or something. :D:D
   / Noisy Hydrostat/Hydraulics? #11
Wait a minute.
You are not required to run 540 RPM PTO implements at 540 RPM. 540 RPM should be regarded as the 'redline' for the implement. Any PTO RPM below 540 that gets the work done (without lugging the tractor engine, of course) is OK to use. In fact, the lower RPMs are preferable as there's a greater margin of safety and less stress on implement and tractor.
I typically run my implements at 80 to 85% of rated RPM. This translates to around 450 RPM. I've never seen the need to push my own equipment any harder than that. If the tractor's running easy and the job's getting done, there's little reason to squeeze out that last 15%.
50 years ago, very few tractors had tachometers, yet PTO driven implements were rated for 540 RPM. The farmer simply advanced the throttle until the work got done adequately with the equipment running easily. That same approach works today.
Bob
   / Noisy Hydrostat/Hydraulics? #12
most of my haying equipment is made to run at 540rpm. i keep it at around 530rpm . running any slower, i don't get good results.
   / Noisy Hydrostat/Hydraulics? #13
I can see where hay equipment particularly balers may need to run at pto speed but there are lots of other implements where it isn't needed. Running at full speed for the most part insures the implement manufacturers will sell replacement implements. I have no interest in haying equipment but tillers, phd's, brush cutters that I have never run at the max speed. A tyopical 2500 rpm motor I will run from 1500 to 2000.
Steve
2004 GMC Sierra 3500 Pickup Truck (A55973)
2004 GMC Sierra...
2022 Ford F-450 Liftmoore 5000W Crane Service Truck (A59230)
2022 Ford F-450...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
UNUSED FUTURE LW45 HYD LOGGING WINCH (A60432)
UNUSED FUTURE LW45...
2015 Ford F-150 Pickup Truck, VIN # 1FTEW1EG6FFA67725 (A59230)
2015 Ford F-150...
