Noisy front end
   / Noisy front end #1
Massey1010
Willamette Valley
I brought my CK20 HST in to do maintenance and jacked the front end up. I spun the tires by hand and the gears sound really loud. Is this normal?
   / Noisy front end #2
Does spinning the tires on both sides sound the same? Are you in 4WD?
   / Noisy front end #3
If it is just gear noise and not grinding, it is normal.
   / Noisy front end
Spinning the tires on both sides sounds the same either direction. I just wasn't expecting it to be as loud as it was. Apparently that is normal.
   / Noisy front end #5
You are probably hearing the front differential (if the other front wheel turns in opposite direction). The spider gears can be noisy (especially if straight cut gears). Normally, engine noise hides gear noises.
   / Noisy front end #6
What is the fluid level. There should be a site glass on the axle tube. When I changed mine, spinning the axles produces some noise, but I would not call it loud. Just a clicking sound.
Hope this helps.
   / Noisy front end #7
Kioti uses the hydro fluid for the front axle lube. This thinner oil might make the gears sound noisey compared to regular 80-90 gear oil.
   / Noisy front end
The fluid level was showing normal in the site glass. When I've changed the fluid in the axle I've used hydro fluid since that was what was in there originally. Gear oil would probably make the gears sound quieter.
2018 Volkswagen Jetta Sedan (A50324)
2018 Volkswagen...
2023 Bobcat T66 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T66...
2025 Icon Electric Bike (A50324)
2025 Icon Electric...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
