Noise Insulation for shop compressor?
   / Noise Insulation for shop compressor? #11
Underground sounds like a really interesting concept especially for a Gen Set. Note to self: Check it out!
   / Noise Insulation for shop compressor? #12
.....but what about condensation and rust?
I've not looked inside since I installed it 5+ years ago so I can't say for sure. I can say I get very little moisture out of it, I've got the timer set for a 4 second blast every 10 minutes and the area where the blast hits shows no rust streaks or staining. There is obviously a stain where the exhaust blast hits because of the moisture exhausted but no rust stain at all.
I'm thinking why there's no rust staining is the short frequency of the blow off (10 minute cycle) doesn't give the moisture time to form rust on the inside of the tank, just my thoughts anyway LOL........Mike
   / Noise Insulation for shop compressor? #13
I put my compressor outside at my old house, my buddy has his compressors outside at his body shop. Only time he had an issue was when the auto drain clogged up and filled the tank with about 50gal of water!
Doesn't seem to have a problem in the winter, but it does get a lot of use so the heat probably helps.
Or just do what I did and get a screw compressor, nice and quiet! you can stand under it and have a conversation. 1551788628.jpeg
   / Noise Insulation for shop compressor? #14
I'm definitely not a fan of 'underground' due to moisture and, especially, heavy rain... and dragoneggs lives in the very rainy Pacific NW.
Last weekend I received 152ml of rain over 3 days. Everything is still sodden and it took this week for the 'moats' to disappear/soak into the ground. It's still 'mushy' to walk around... I'd have to pump out any underground facility.
   / Noise Insulation for shop compressor? #15
Mark, here's a few ideas
17 Ideas on How to Build a Soundproof Box for Air Compressor
I can't say I agree with all of the choices there, just some ideas - also, here's a thread that went on during the 8 years or so I moderated construction on this site
John Sayers' Recording Studio Design Forum •
View topic - from shed to studio?
My screen name there is knightfly.
You'll need to join (free) in order to see any of the several sketches I drew for the OP; unfortunately, pics from the OP didn't survive. The techniques remain the same, you could just scale them down to fit your compressor.
I no longer have license to some of the software I used to use (not cheap and not doing that any more), but generally you should start with knowing what frequency components your compressor generates the most; can be done with a free android app called Spectrum Analyzer - next would be finding which materials/thicknesses, etc, will give best attenuation of those frequencies. If EITHER side of a double wall (aka Mass-Air-Mass, same concept as Mass-Spring-Mass, since air is a spring) is resonant at the offending frequency, there'll be nearly NO attenuation.
Don't bother to respond to that thread, the OP is long gone and I don't frequent there regularly any more either; got too burned out and too little progress on MY stuff.
Oh, if anybody tries to sell you "soundproofing" foam, RUN AWAY - most of it is NOT fire resistant, and insulation like Roxul's safe-n-sound works MUCH better.
If you like, PM or call me and I can dispel a few more myths... Steve
   / Noise Insulation for shop compressor? #16
At work they just built us a new classroom and office space for a 20 booth welding program. They used R-11 insulation and 1/2 inch soundboard and we can carry on a conversation in the office or classroom without raising our voices with welders/tools/air handlers going.
   / Noise Insulation for shop compressor? #17
I love the Roxul products, used the safe n sound when I redid the downstairs bathroom to help quiet down certain errr, noises, since it's by the dining room.
When I reinsulated the attic in the house a couple years ago I used the comfort batts, very happy with their products.
   / Noise Insulation for shop compressor? #19
what type of compressor and how loud? I've got a Quincy Q-5 that runs at 1800 RPM - note this isn't the QT-5 available from Rural King/Northern that runs at 3600 RPM. It isn't loud at all. Before you invest too much time and trouble in building a room, maybe solve your issue with just a new compressor. My compressor sets on 4 rubber pads and loosely bolted through two of them. You can have a conversation right next to it and talk in a normal voice.
   / Noise Insulation for shop compressor? #20
Closet/outhouse is probable best solution, yes you can insulate it for sound, make sure it has ventilation (convection is fine).... Get drain valve assembly that automatically operates with unloaded so draining does not becomes issue....
Dale
2002 Frieghtliner Pressure Digger (A55973)
2002 Frieghtliner...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
Butterfly Artwork (A55758)
Butterfly Artwork...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2025 GIYI MULCHER SKID STEER ATTACHMENT (A58214)
2025 GIYI MULCHER...
405 (A52706)
405 (A52706)
