Noise Insulation for shop compressor?
   / Noise Insulation for shop compressor? #101
Still about 2 times more than I would spend. If trying to make a living with it, maybe.
   / Noise Insulation for shop compressor? #102
I know what you mean. At one time, I had a use for all my air tools and spray guns. Now, I use air to blow off the mower and fill tires.
   / Noise Insulation for shop compressor? #103
I also wonder about the longevity of aluminum pumps vs the venerable cast iron pumps?
   / Noise Insulation for shop compressor? #104
I get the log scale for dB and that is a huge drop, but honestly I don't have a clue what 5x means in terms of audible sound. Need to hear it side by side.
Worth it... nope. Got other tools I 'need' first. Time to get on with the design of the outhouse for the compressor. Doghouse is covered... that is my shop. Recently plumbed for a sink and small fridge, just need a foldable cot. :laughing:
My large screw compressor is rated at 70dba, I can say it is just a hum in the distance, especially compared to my standard 7.5ho 2 stage reciprocating compressor. I couldn't find the dba rating on it but i imagine it would be close to yours. I imagine 75dba would be pretty tolerable.
Okay a bit deeper dive into my Husky 3.7hp 60gal compressor...
Pulleys
Motor = 4in
Compressor 12in
Centers 10in
Motor = 3450rpm
Compressor = 1150rpm
Compressor is mounted on double sheet of 3/4in plywood and HF 3in polyurethane casters.
Noise (pretty much against wall)
88dB @3ft
85dB @6ft
Noise (compressor 3ft from wall and rotated 90deg so front/back not facing wall)
86dB @3ft
83dB @6ft
Compressor intake on top with filter on side. 2 intake ports about 1.25in by .5in (a little smaller but couldn't fit my calipers)
View attachment 667351 View attachment 667352
Checked noise to compare with OEM intake filter on/off:
Noise (compressor 3ft from wall and filter ON)
86dB @3ft
83dB @6ft
Noise (compressor 3ft from wall and filter OFF)
88dB @3ft
85dB @6ft
   / Noise Insulation for shop compressor? #107
Though everyone seems to agree a cast iron pump is quieter and would last longer, my home compressor is a Campbell Hausfeld V-twin, it's belt driven with an aluminum pump, 30 gallon tank, and a true 4hp motor.
It was not cheap, ($780, in 1984). But, it was a light commercial grade unit, and it's the quietest compressor I have ever heard.
This compressor has a lot of hours on it, many of them hard hours. And, the aluminum pump has never needed any repair.
If you consider the reality that the tank has reached the limits of it's useful life, the pump has effectively out lasted it.
I have owned both cast iron, and aluminum compressors commercially as well, and I do not consider an aluminum pump a liability.
   / Noise Insulation for shop compressor? #108
Good to know. Thanks
   / Noise Insulation for shop compressor? #109
There is also the possibility that the aluminum compressor has a cast sleeve for the piston to run in.
I just ordered 12sq ft (1ft squares) of insulation panel. Will experiment with them in the compressor's current indoor spot and see if they are effective. If not, I have another project that I can use the insulation.
Speaking of noise insulation... the dang squirrels are waking us up in the early mornings. They are picking and dropping (intentionally throwing) green pine cones on our roof above the bedroom. They are about to be served a 22 pill.
2021 Ford F-150XL (A57148)
2021 Ford F-150XL...
DEUTZ MARATHON...
Game 93ATX (A57148)
Game 93ATX (A57148)
PALLET OF BAR LOCKS (A58376)
PALLET OF BAR...
HITACHI EX550LC EXCAVATOR (A58216)
HITACHI EX550LC...
Gilson Brothers 57006 (A57149)
Gilson Brothers...
