noise in kubota b2630
   / noise in kubota b2630 #1
1396
my b2630 recently started making noise only in high range.The dealer said it is hydraulic noise. when i press down on peddle i hear a high pitch noise. After it warms up it stops. It never did it before.anybody hear the same noise?
   / noise in kubota b2630 #2
Mine does not do it. Yet that is (knock on wood)! How many hours do you have on it and is the dealer telling you that noise is normal?
   / noise in kubota b2630 #3
Do a couple things to assure your mind.
1. Check HST fluid level? Already have, no doubt.
2. Pull the HST screen and clean it. If you use a cork or rubber plug, you won't hardly lose enough to speak of. Top off the few ounces you might lose.
3. Park the tractor, after a solid use, on a clean dry spot on cement, in your garage or shop. A place that is very clean. Or, park it on clean, dry cardboard laid out on the floor. Look for ANY spots of fluid after 24 hours.
The reason I mention this last item is that if there is a loose fitting somewhere, anywhere, the leak drip will show up eventually. Mine came with a loose hydraulic line fitting. Once I found that loose fitting and tightened it, my HST was noticeably quieter. If a fitting sucks a little air, the noise is quite bad.
In any case, these HSTs are not quiet by any means. Best Wishes
My kubota has 148 hours on it. I changed both transmission filters and new fluid. Where is the HST screen located...nowhere in my manual.
i have 148hrs on tractor.Changed both transmission fliters and hd fluid.
   / noise in kubota b2630 #6
Did you find the HST screen? To find it, crouch down very low facing the rear of your tractor. On the bottom left of the rear end, you will find a large, 1 inch sized cap, a nut. That is the cap nut that you must remove to gently pull out your screen. Have a tapered cork or rubber plug ready. You can stop up that hole and not lose but a few ounces of your sudt fluid.
Messicks have a step by step photo series on their website, I believe, It might help you.
http://www.messicks.com/Articles/KubotaBX-Service.aspx
Perhaps you already found it, and cleaned the screen? Has the noise subsided since you changed your fluid?
   / noise in kubota b2630 #7
I don't think his B2630 has a screen. I was looking for one when I did my hydraulic service on my B3030 & couldn't find one. I called the dealer & asked. They said it didn't have one. Maybe Messick's will respond & confirm this.
   / noise in kubota b2630 #9
I have a 2006 B2630 and it squeals every winter. I have noticed that it only happens when the tractor is in motion. Therefor indicating transmission and like yours will stop once the tractor warms up. I am using UDT but my dealer recommended it for this climate. I have also noticed that the noise gets louder as the RPM's increase.
   / noise in kubota b2630 #10
Sometimes small leak will suck enough air to cause a louder whine in the HST. I know mine did until I found the line coupling loose and tightened it.
Apart from that, a bad HST fluid filter, or an O ring from the old filter being left on there, so that now there are two rubber O rings on the HST filter.
Also, if the noise is only during warm up, this is precisely where Super udt is a superior product and why, I believe, Kubota went to it. It is quick flow, quicker to warm up, and multi grade at a lower flow rate. It's worth a try, really, really is. These HSTs are noisy enough when all is well.
IH Farmall 706 Tractor (A50514)
IH Farmall 706...
MISC, 3 MAN HUNTING BLIND, FISHING POLES (A51244)
MISC, 3 MAN...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
Blue Diamond Quick Attach 6 Way Blade (A50514)
Blue Diamond Quick...
2013 Hyundai Sonata (A50324)
2013 Hyundai...
36 (A51242)
36 (A51242)
