noise from 2045 bush hog loader
/ noise from 2045 bush hog loader #1
dodgetruck
eleva wisconsin
agco st34a
have a agco st34a with a bush hog 2045 loader . when 1st starting up tractor and raising loader , jerks , for 3 - 4 seconds , after that is fine . when tractor runs will hear a growl in hydralics once in awhile , not all the time .
/ noise from 2045 bush hog loader #2
Jerking and noise would point towards air getting sucked into the pump. This can be from a partially plugged inlet screen or filter, low oil level, pin hole or leak in the inlet line, thick oil from cold temperatures, etc.
thank you , will ck all mentioned .
2013 Felling 25' x 102 Tag Trailer (A62613)
2013 Felling 25' x...
2006 Toro SandPro 2020 Bunker Rake (A61572)
2006 Toro SandPro...
2025 GRIFFIN DUMP TRAILER (A59910)
2025 GRIFFIN DUMP...
2461 (A58376)
2461 (A58376)
6 1/4 INCH OD 90 DEGREE ELBOWS (A63569)
6 1/4 INCH OD 90...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
