noise from 2045 bush hog loader
/ noise from 2045 bush hog loader #1
dodgetruck
eleva wisconsin
agco st34a
have a agco st34a with a bush hog 2045 loader . when 1st starting up tractor and raising loader , jerks , for 3 - 4 seconds , after that is fine . when tractor runs will hear a growl in hydralics once in awhile , not all the time .
/ noise from 2045 bush hog loader #2
Jerking and noise would point towards air getting sucked into the pump. This can be from a partially plugged inlet screen or filter, low oil level, pin hole or leak in the inlet line, thick oil from cold temperatures, etc.
thank you , will ck all mentioned .
2019 ISUZU NPR 4X2 S/A 20FT BOX TRUCK (A59910)
2019 ISUZU NPR 4X2...
2020 Kinze 3505 High Speed 6/11 Planter (A63118)
2020 Kinze 3505...
2019 JCB 457 (A60462)
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
2024 John Deere 8R 410 Tractor (A63109)
2024 John Deere 8R...
2016 Ford Fusion Titanium Sedan (A61574)
2016 Ford Fusion...
