NOCO Genius question
   / NOCO Genius question #1
2515R Dude
Platinum Member
KY
Branson 2515R
Last week i bought two NOCO Genius1 chargers/maintainers.
I put them on two different batteries, one is 800CCA marine and another is a small 230CCA ZT.
Both batteries were fully charged before i connected NOCOs. Both chargers were blinking red light for a few seconds then went solid green.
It is already 4th day they are on and still they are solid green without going to the next step - blinking/on/off green which indicates "maintenance" stage.
The question is, is it a normal behavior?
   / NOCO Genius question #2
I have them on all my 6v tractors, that’s how they act. Some work at different speeds between modes, guess every battery is a bit different
   / NOCO Genius question #3
the lights are based on voltage., they blink green for a long time, while pumping out full current.
it NEVER go to the "pumping" green mode. Stays solid green. And the voltage is constant 12.7V so far.
How long does it take till is starts "pumping"?
   / NOCO Genius question #6
put an amp meter on it, how much current? 12.7 is not full charged, they rest around 13.2
   / NOCO Genius question #7
Sorry I duplicated your post sir. I’m not sure how to determine a fully charged battery with these. I think it’s almost completely green I had one intermittently blinking and it would not start my car. Left it on until the next day and it did. And it was almost on all time. I have the 10 amp. They are good chargers
It starts from 13.9V with red pulsing, then go to 12.9V with solid green, then go to 12.7V with solid green.
   / NOCO Genius question #9
You would need a dc amp meter like this to determine what's going on.
   / NOCO Genius question #10
It starts from 19.9V with red pulsing, then go to 12.9V with solid green, then go to 12.7V with solid green.
19.9 is a bad sign, typically indicates the battery is shot, do you have a load meter?
2019 Toyota Corolla Sedan (A55853)
2019 Toyota...
Kubota L4701 (A53317)
2017 CATERPILLAR 120M2 MOTORGRADER (A52709)
2017 CATERPILLAR...
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
2016 Bobcat E85 Midi Excavator (A56857)
2016 Bobcat E85...
2021 MULTIQUIP 25 WHISPERWATT DIESEL GENERATOR (A59823)
2021 MULTIQUIP 25...
