No Ujoint on driveshaft on Kubota B
   / No Ujoint on driveshaft on Kubota B #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
I did the 50 hour service on the B2601. So, while I was down there, I took a look at the Kubota's driveshaft from engine to HST.
NO Ujoint there. There's a coupler that probably allows to/fro sliding to accommodate thermal movement, but no Ujoint. Cannot see the back. Probably none there either.
Ralph
You sure its not a CV (constant velocity joint)...
Nope, just a real simple slip collar. I know what CV joints look like. Had them on swing axles of the Benz and now on the Miata. They're big. This is a tiny slip collar.
Have no idea what's in the back, as I cannot see it. Suspect it's a thing like was on the front of the Benz's driveshaft (to fixed diff), e.g. more like a tire sidewall with 4 steel reinforced holes. Gotta be something, I'd think, to allow that slip collar to come off, or maybe you just loosen the allen screw and slide it back.
2021 Kubota SVL97-2HFC Compact Track Loader (A50657)
2021 Kubota...
Chevrolet Silverado Pickup Truck Bed (A49461)
Chevrolet...
2013 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2013 INTERNATIONAL...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
2015 MACK GU713 (A50854)
2015 MACK GU713...
2016 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2016 VOLVO VNL...
