No Ujoint on driveshaft on Kubota B
   / No Ujoint on driveshaft on Kubota B #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
I did the 50 hour service on the B2601. So, while I was down there, I took a look at the Kubota's driveshaft from engine to HST.
NO Ujoint there. There's a coupler that probably allows to/fro sliding to accommodate thermal movement, but no Ujoint. Cannot see the back. Probably none there either.
Ralph
You sure its not a CV (constant velocity joint)...
Nope, just a real simple slip collar. I know what CV joints look like. Had them on swing axles of the Benz and now on the Miata. They're big. This is a tiny slip collar.
Have no idea what's in the back, as I cannot see it. Suspect it's a thing like was on the front of the Benz's driveshaft (to fixed diff), e.g. more like a tire sidewall with 4 steel reinforced holes. Gotta be something, I'd think, to allow that slip collar to come off, or maybe you just loosen the allen screw and slide it back.
2014 Ford F-250 Crew Cab 4X4 Pickup Truck (A55973)
2014 Ford F-250...
jet ski trailer (A56859)
jet ski trailer...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A56435)
2016 RAM 5500...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
2025 SDLANCH TRAILED CRUSHER (A58214)
2025 SDLANCH...
2008 Ford F-150 Ext. Cab Pickup Truck (A56858)
2008 Ford F-150...
