No start
/ No start #1
Ctheroofer
Port huron, michigan
Kioti DK 45
Hello everyone,
I have a 2004 kioti dk45 with 515 hours
Terrific tractor
However I was doing routine maintenance I cleaned lights and sprayed a cleaner at plug adapter then put back together. Then after cleaning fuel filter putting valve to air I was turning engine over when suddenly it began to make shorting out ( wires frying) sound
Now I turn the key and get nothing no silicosis sound no dash lights nothing dead.
The battery is properly connected and charged.
Any ideas?
/ No start #3
Sounds like a bad battery cable connection or a bad ground at the frame connection to me.
The first thing I would do is remove all battery cables and clean all connections.
/ No start
Hello Vince,
I thought same thing since I was cleaning battery cables etc during maintenance I was doing.
So battery is good and it simply shorted out while turning over after cleaning fuel filter. I thought maybe the cleaner I sprayed in connection for lights some how caused shorted it out. ( took off front grill to get to battery and cables and had to unplug lights connection was lightly corroding so I sprayed to clean)
I appreciate your thoughts.
/ No start
Scott,
Great question. Didn't think of that. Thank you for the consideration.
I just tried flashers. They didn't work however I heard a clicking sound ( clickk click click) under the dash. Then it quit. So I immediately checked battery connection again and put charger on it. No difference still nothing not even the clicking ( fluttering sound) under dash.
Would a bad rely switch cause no power at all?
/ No start #6
Scott,
You have a bad ground or a discharged Battery. hopefully James or CM see this thread and chime in as the are good with the Electrical stuff.
/ No start #7
If the lights work the old method for checking battery/connections is turn on lights try to start: if they dim its may be a weak battery and if the lights go out look for a connection.
/ No start
Good evening Scott,
You were correct it was a bad ground actually the wire it self was corroded inside protective vinyl ( unseen )
Thank you the flasher question was the one that really got me thinking had to be ground or battery.
Great job please let others James CM know also.
/ No start #9
Good evening Scott,
Your welcome but I'm not Scott
/ No start #10
... I just tried flashers. They didn't work however I heard a clicking sound ( clickk click click) under the dash. Then it quit. So I immediately checked battery connection again and put charger on it. No difference still nothing not even the clicking ( fluttering sound) under dash. Would a bad rely switch cause no power at all?
If the flashers don't work, that pretty-much narrows it down to one of the battery cables (including end connections) or the fuse. There have been several reports here about failed cables where the bad spot was under the insulation. I think the fastest test is to use a jumper cable from the battery negative to bare metal on the engine (bypass ground cable) to see if that fixes your problem. Similarly a jumper cable from the battery positive to the big terminal on the starter would bypass a problem with the positive battery cable. If all that checks out, check the fuse but the noise you described sounds more like a bad cable/connection.
/ No start #11
Replace the entire cable from chassis ground bolt to battery negative post connector. Coat all in anti corrosive grease like copper anti-sieze and use the felt washers under the battery post clamps and then spray battery protecting spray on ALL terminals, and the battery ground bolt on the chassis. Check regularly and correct any damage.
/ No start #12
I second the copper anti-sieze. I used it on the ground cable and bolt to the frame. Also used the felt washers under the battery post clamps along with spraying them with the dark red/purple protection spray. It's been 6 years since doing that. I always give them a check during normal service but no problems/corrosion.
/ No start #13
Atta boy! It is the ONLY way to keep corrosion at bay on these machines. And it WORKS great!:thumbsup:
I use this method on all my vehicles and it prevents premature death to batteries, cables, wiring, etc.
Landhonor 72" Skid Steer Power Rake (A62679)
Landhonor 72" Skid...
2022 EZ-GO ELITE...
2022 EZ-GO ELITE...
2023 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2023 CATERPILLAR...
2018 ROCK SOLID CARGO 14 T/A SHOWER TRAILER (A65643)
2018 ROCK SOLID...
2016 HEIL TRAILER (A65643)
2016 HEIL TRAILER...
