No Start Condition John Deere x595
   / No Start Condition John Deere x595 #1
rdschomm54
Ohio
John Deere x595
Hello,
I just serviced my X595 and mowed about 4 hours. I stopped for about an hour and went to restart to continue but it will not start. Battery is good, Starter checks out. I also checked seat switch, The mower deck switch and the brake interlock swtch which are all good. I checked the fuses and relays all tested good. I turn the key on and hear a few clicks and everything lights up as normal. I turn the key to start position and hear one click and then nothing. Could this be the Ignition Module Switch combo?
Hopefully someone out there has had a similar experience.
Thanks!
   / No Start Condition John Deere x595 #2
Welcome to TBN. :)
Thank You!! I'm new at this so was this the correct place to post this or should I repost it to another spot
Bob
   / No Start Condition John Deere x595 #5
Might post in the JD forum but most every body reads thenew post section. You might have a safty switch not making contact!
:welcome: to TBN! :thumbsup:
Happy :tractor: ing!
   / No Start Condition John Deere x595 #6
WELCOME to TBN :)
I moved your thread to the John Deere Lawn & Garden Forum.
   / No Start Condition John Deere x595 #7
Could be a dud PTO switch - does not seem uncommon for those to go out after 5-6 years. Fairly cheap to replace, so might be worth a try.
Tim
   / No Start Condition John Deere x595 #8
I'm thinking more along the lines of a bad solenoid, if the dash lights come on then you turn the key to start and it just clicks. Then you deffinetly have a bad solenoid. It is an easy fix, just keep track of where the wires bolt onto. Just be ready for sticker shock when you go to the parts counter.
   / No Start Condition John Deere x595 #9
There is another thread going on this same question. Unfortunately.
Hello
I posted the original post to the wrong forum due to my lack of experience in these things. It was moved to the Lawn&Garden Forum where it should have been. I want to thank everyone for the replies. I have solved my issue with the tractor by replacing the Ignition Module Switch combination. I appreciate everyones ideas because they were all valid checks. I did check all and ended up narrowing it down to the Module.
Thanks again!!
Bob
2003 VIKING  CEMENT MIXING TRAILER (A45046)
2003 VIKING...
2011 DRAGON PRODUCTS 150BBL ALUMINUM VACUUM TANK TRAILER (A45046)
2011 DRAGON...
Towable Message Board (A44571)
Towable Message...
2019 Freightliner M2 106 Elgin RegenX Sweeper Truck (A44571)
2019 Freightliner...
ASV Posi Tool Backhoe Quick Attach (A44391)
ASV Posi Tool...
2021 Kubota L2501D 4x4 Tractor with Loader (A44391)
2021 Kubota L2501D...
