No power to start my Mahindra 6000 4WD
   / No power to start my Mahindra 6000 4WD #1
Oorah
Luther, Oklahoma
Mahindra 6000 '00' Series 4WD
Recently clearing woods and stopped for an hour break. When I came back there was no power to the switch. Gages are dead, no starter click even. I have looked for a few hours on the forum but no luck on finding a fix.
I replaced the starter relay switch no help there. Fuses seen ok.
any help appreciated.
   / No power to start my Mahindra 6000 4WD #2
Check to see if your PTO levers are disengaged.
   / No power to start my Mahindra 6000 4WD #3
PTO lever makes no difference on a 6000..its all mechanical..I'm just guessing here, but it may be a "fuse" or fusible link..I think there is one near the the switch...Did you get the care package with your 6000? (ie. the zip locked pack in your lower "glove box"...the "other" place you can stick the key in below the starter switch? BobG in VA
   / No power to start my Mahindra 6000 4WD #4
I believe, near the starter, you should find a pigtail with a fuse in it, that if blown it will enterupt power to the whole tractor.
1982 TANDEM AXLE CEMENT MIXING TRAILER (A50854)
1982 TANDEM AXLE...
2008 FORD F-450 (A50854)
2008 FORD F-450...
2015 FONTAINE VELOCITY 102" X 48' STEP DECK TRL (A50459)
2015 FONTAINE...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
1995 FORD LT9000 DUMP TRUCK (A51222)
1995 FORD LT9000...
2012 Ram 1500 4x4 Crew Cab Pickup Truck (A49461)
2012 Ram 1500 4x4...
